1. Ttsuam
    Ttsuam New Member
    Monday
    Michigan
    2019 Prius
    XLE AWD-e
    Hello,
    I’ve recently bought a 2019 AWD XLE and when i was on the test drive i noticed a humming from the rear. I guessed that it was a wheel bearing since it seemed to sound the same and change when turning and with speed.
    I replaced one rear wheel bearing without giving the wheel a good shake to feel for looseness because i was confident i knew the issue, but the noise hasn't gone away.
    Could it just be road noise? This is my first prius and didnt test drive any others so I dont have a baseline. Any other ideas what it could be? I plan on changing the transmission/dif fluid soon anyway.
    51,091
    could be the other side or a tyre. how many miles on her?
  3. BiomedO1
    BiomedO1 Senior Member
    2,777
    1,474
    SacTown, Ca
    Did you check the fluid level in the pumpkin and/or has it been ever checked or changed?
    This is neither here or there; but why did you buy it like that and not insist on them fixing that first? Has that car been in an accident before?
