Humming noise from front of car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nozzavtr, Jun 23, 2019.
  1. Nozzavtr
    Nozzavtr Active Member
    155
    199
    United Kingdom
    I have a low humming noise coming from the front of the car, 2008 Prius, 127,000 miles. It is only noticeable at speeds over 25mph, then seems to go after 35mph, I've coasted in neutral and the noise is still there, more noticeable when decelerating. Tyres are 3 years old, about 4mm tread left, all matching Falken all the way around. I've jacked the car up and no movement in both front wheels, so at a loss.
    Does anyone have nay ideas at all? Thanks.
  2. Nozzavtr
    155
    199
    United Kingdom
    I also believe that the noise disappears when turning right, can’t guarantee it though, front left bearing possibly?
  3. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    My first guess (and it is a guess) would be a wheel bearing. While most Prii never lose a bearing, that is one of the more frequent repairs. I'd raise the front end, put it in neutral and spin the wheels to see if I could feel anything. You might not feel movement unless it's really shot, but you might feel a slight vibration when rotating the wheel.
  4. Nozzavtr
    155
    199
    United Kingdom
    Thanks for that, I’ll jack the car up at some point and give that a go. The noise isn’t very noticeable, so hoping that if it is the bearing it’s in the very early stages, but will give it a go regardless.
  5. ChapmanF
    15,697
    jerrymildred likes this.
  6. Nozzavtr
    155
    199
    United Kingdom
    Thanks for pointing out the other thread, I should of done more research on here. Admin, please cancel this thread if it helps.
