Humming noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 1quayle, Mar 13, 2016.
Tags:
  1. 1quayle
    1quayle New Member
    Iowa
    Three Touring
    What causes humming noise in front while driving and it gets louder when turning right?
  2. TampaPrius.com
    TampaPrius.com Active Member
    461
    298
    Tampa, Florida
    Most likely wheel bearing. Could also be cupped tires.
    kenoarto likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    Humming from front is either bad tires...or bad wb...or if only on the passenger side may be blown transaxle.
    Whats the miles and has the trans fluid every been replaced?
  4. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    As the others have stated, most likely a bad drivers side wheel bearing since it gets louder when turning right, which is putting more load on the left wheel.
  5. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Same sound here. More of a howl to me! If it's making a noise when you turn to the right, then it is probably your left bearing. Had both of my front wheel bearings replaced 2 weeks ago. Car-X did that plus disks, rotors, water pump and transaxle fluid for $1000 out the door (included all taxes and shop fees). Toyota wanted $3000! Car is quiet again. 10 years/100,000 miles will do again, if needed.
    #5 kenoarto, Mar 14, 2016
  6. 1quayle
    1quayle New Member
    Iowa
    Three Touring
    157,000 miles,tires are good and trans fluid not changed since I got it at 80,000.Going to shop tomorrow. Thanks everyone.
