HV baterry fan does not work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by woodziak, Sep 17, 2020.
  1. woodziak
    woodziak New Member
    Norway
    Hello everyone.
    I am dealing with hv battery overheating. Fan does not start. It has been checked and fan itself is ok. It looks like there is no power in the fan connection. Do You have any ideas what should i check to solve the problem?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    What are the reported OBD2 codes (DTCs) when you scan the vehicle with a toyota hybrid compatible OBD2 reader?
    Once you have the codes, post them here for additional guidance.
    You could check this connector for corrosion :
    edthefox5 likes this.
