HV battery Cell replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by jichi, Feb 22, 2017.
  1. jichi
    jichi Junior Member
    i had a problem with my prius 2006 hv battery failing block number 3
    and i took the battery apart and measured all the cells and each cell measured 8.24 to 8.27except one measured 6.99 and it was cell number 5
    8.27
    8.26
    8.25
    8.24
    6.99
    8.23
    8.24
    8.24
    8.23
    8.25
    8.26
    8.25
    8.25
    8.25
    8.24
    8.25
    8.26
    8.26
    8.24
    8.26
    8.24
    8.25
    8.25
    8.27
    8.25
    8.27
    8.26
    8.28
    so i went ahead and replaced it with a cell measuring 7.59V.
    i tried to nimh special charger before i did that but for some reason it did not work.
    i put the battery back together put it in the car drove the car with no problem for two weeks. checked it again and now block 9 failed.
    my question is it because the voltages for the cells were high around 8.24V thats why the cell is failing one after the other. or is because I did not balance them although you can see all the blocks have 16.7Volts.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When you have an HV battery apart, you need to load test every module and replace those that do not maintain their voltage compared to the others. Just looking at the resting voltage is not a sufficient measure of module health.
    Jeffd
    MTL_hihy likes this.
  3. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
  4. jichi
    jichi Junior Member
