HV battery cooling fan
Discussion in 'Gen 3 Prius Technical Discussion' started by PriusGuy32, Jan 30, 2020.
  1. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    I’ve been in my new-to-me 2015 Prius four since 6am this morning, Driving mostly non stop to Florida (1,400 miles). Been getting spectacular highway gas mileage on each fill up (46-49mpg!). We’ve been rotating drivers so I’m now in the back seat, and I noticed the HV battery cooling fan running on a low speed. We have been in heavy stop and go traffic in Atlanta for at least an hour. Guessing this is pretty normal for driving the car all day, through mountains and with 3 grown adults and all Of our luggage? :eek:
    By the way, I’ve only got 18,000 miles on the car and it’s certified pre owned. No indications of any battery trouble, and I’ve never heard the fan running.
    I only knew it was running because out of curiosity, I stuck my hand near it and felt a little rushing air in. As a test, I stuck a tissue to the hv fan grate in the back seat, and it stuck.
    RMB and Aaron Vitolins like this.
  2. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    All good, all normal. Drive safe!
    PriusGuy32 likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,243
    3,781
    I hope you removed the tissue. :)
    That's pretty good mileage for all the people and luggage.
    What part of Florida are you heading too? Business or pleasure?
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Yup totally normal! You’ll be surprised how much air it will suck through that vent, especially after an hour of stop and go traffic in the summer!
  5. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    To maximize the lifespan of your vehicle, try to avoid parking in full sun with all the windows rolled up for long periods of time. This alone can make a huge difference in how often the fan has to run to cool the pack... Stop and go traffic tends to heat the pack up too... Basically, the cooler you keep your pack, the longer it will last!
  6. Grit
    Grit Senior Member
    6,454
    4,189
    Wilkes Land
    I could swear some other threads say avoid extreme cold and heat. Extreme cold is the way to go then.
  7. PriusCamper
    12,064
    4,896
    By keeping a pack cool I specifically mean keeping between 75-98 degrees Fahrenheit... Once you get above 100 for prolonged periods of time things start unraveling, which is why hybrid battery problems are most common in late Spring when Summer heat starts kicking in.
    RMB likes this.
  8. ASRDogman
    7,243
    3,781
    Batteries work best and last longer when kept in the specific range they are designed to work in.
  9. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Make sure your hybrid battery is good.
  10. PriusGuy32
    1,417
    513
    headed to Fort Lauderdale, leaving on a cruise Saturday! So lotsa pleasure :cool:
    oh, no worries, she’s swell. And even if it wasn’t, I’m under warranty for another 80,000 miles and 3-4 years. I’ve only got 18,000 miles on the car right now, and it’s spent it’s entire life in the very mild Midwest.
  11. ASRDogman
    7,243
    3,781
    Enjoy your cruise! I'm a landlover a few hours north of lauderdale...
