HV Battery Date Code
Discussion in 'Knowledge Base Articles Discussion' started by ITBland, Aug 26, 2018.
  1. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    This TSB has the instructions for reading HV battery module date codes:
    Some additional information from senior members here:
    To read the date code on the case of the battery (no guarantee that the modules have not been swapped!):
    Great description and pictures of a new battery pack from Toyota from @3prongpaul :
    Is there a way to determine if HV battery is the original?
    Thanks to all the senior members here at PC!:notworthy::notworthy::notworthy:
    EDIT: Special thanks to @dolj :notworthy: for catching error on the graphic (now corrected)
    #1 ITBland, Aug 26, 2018
  2. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    The battery module in the image actually was made 19 Sep 2015; The 4th character is a "Q" not an "O".
  3. ITBland
    433
    272
    Arrrgh! :oops:Thanks for spotting that, I’ll see if I can update the picture!
    Edit: Graphic in post #1 updated to correct year. Thanks @dolj :notworthy::notworthy::notworthy:
    #3 ITBland, Aug 26, 2018
  4. draghiceanu
    draghiceanu New Member
    Romania
    i have serial number " 119R6S09533Y " on HV battery . how old is pls
  5. dolj
    dolj Senior Member
    7,648
    3,858
    If it follows the same numbering as Prius modules, then it would be 11 Sep 2016. But I have no idea if it does, but can't think why it wouldn't. Toyota doesn't usually reinvent the wheel, and I imagine the same modules would be used across the whole hybrid range, rather than have special number sequences per model.
  6. Rammmah
    Rammmah New Member
    jordan
    i have serial number " 105KAG01036BB2 "
  7. dolj
    dolj Senior Member
    7,648
    3,858
    See first image in post #1
  8. priusPHEVcruiser
    priusPHEVcruiser Junior Member
    Hello,
    i have a question!
    newer Cells, say 2018, are not listed in the Table above.
    I am right, 2018 is Letter "T"
    I have Cells with Serial "058TAA00852Y"
    So they made 05 May 2018?
    THANK YOU!
  9. priusPHEVcruiser
    Hello,
    OK .... i hope this is true!
    "After 2015 the letters go sequentially. i.e. R=2016, S=2017, T=2018, U=2019 etc."
    Greets
  10. dolj
    dolj Senior Member
    7,648
    3,858
    Yes, it is.
    Almost! It is actually 05 Aug 2018 viz a vie:
    05 = Day - 05
    8 = Month - August
    T = Year - 2018
    #10 dolj, May 10, 2021
  11. Mihai Milix
    Mihai Milix New Member
    Bucharest
    can you please help me identify more details regarding this battery? It’s a pack from an 08 Lexus LS600hL
  12. dolj
    dolj Senior Member
    7,648
    3,858
    It looks like it uses the newer decode so this battery has a manufacture date of 31 Oct 2017.
    #12 dolj, Jul 29, 2021
    Mihai Milix likes this.
  13. Mihai Milix
    Bucharest
    Thank you!
  14. Joao
    Joao Junior Member
    23
    Portugal
    posting this one from a similar thread. Can anyone help me identify the year of this module?
  15. PriusOwner428
    PriusOwner428 Junior Member
    40
    IL
    So what do I have?
    H147NAJ0016A
    I assume the date is July 14, 2010, but what do the "H" & "J" mean?
    It says Panasonic on the label with the code, so why is there a "J" where the "B" should be?
  16. dolj
    dolj Senior Member
    7,648
    3,858
    You didn't like the information given in that thread?
  17. dolj
    dolj Senior Member
    7,648
    3,858
    Yes, that is correct assuming you're talking about the date code sticker on the outside of the battery.
    The first character H is supposed to indicate the model of vehicle for which the battery is made, which for a Prius is supposed to be F. But in reality, I have never seen F on a battery S/N only H.
    The position which has J is supposed to signify the manufacturer of the ECU. I have no idea what manufacturer J indicates.
    #17 dolj, Feb 20, 2022
    PriusOwner428 likes this.
  18. PriusOwner428
    40
    IL
    Thanks. I saw the H, but just visually knew that it was a pack for a gen 2 Prius.
  19. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
    You may note the picture in post #1 is the end cap of a Gen 1 Prius HV battery. The Gen 1 Prius batteries have an F. Every single one I've ever had my hands on, has been an F. On the other hand, every Gen 2 has an H. Just a little glitch in the decoder, most likely due to the decoder photo being current around the same time a Gen 1 was current.
  20. PriusDadNoob
    PriusDadNoob Junior Member
    62
    There is mention of newer and older battery pack serial number decoding and I'm a little confused. Can anyone help with this serial number on my 2006 Prius battery?
