HV Battery Failing
Discussion in 'Gen 2 Prius Technical Discussion' started by magruder, Sep 25, 2009.
  1. magruder
    magruder Average Member
    145
    Colorado
    I believe my HV battery is failing. The charge can go from full green to one red (or the other way around) in less than a minute. I have not noticed a drop in mpgs yet though. However, last night the hybrid system warning light came on (the one with the exclamation point in the middle of the car, on the MFD screen). How long do you think I have to replace the battery? Can I wait a little while? Or should I not drive the vehicle for some reason until I replace the battery? Could I be mistaken and there may be some other problem? I haven't gone to a Toyota dealer, and I'm not planning to.
    Thanks,
    Dave
  2. Patrick Wong
    18,198
    6,461
    Hi Dave,
    I think that your belief is justified. Soon you'll get to the point where the gasoline engine will run whenever you depress the accelerator pedal. At that point the car will not be very easy to drive because it will lack power especially from a standing start.
    I recommend that you start looking for a good salvage battery since it sounds like you're planning a DIY replacement. Good luck.
    2 people like this.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Ditto Patrick's remarks...sorry to hear that.
  4. magruder
    145
    Colorado
    Thanks,
    I guess I'll lose reverse when the battery goes completely as well. Is it most important to get a low mileage battery, or is the age important also?
  5. Patrick Wong
    18,198
    6,461
  6. magruder
    145
    Colorado
    Thanks Patrick,
    I did see that battery, and it looks like a good choice. I also checked, and there are quite a few available at the local junk yards. I may pick one up here in Denver.
    Regards,
    Dave
  7. richard schumacher
    7,663
    1,037
    United States
    I gather that yours is out of warranty? [I rarely bother to turn signatures on.]
  8. Patrick Wong
    18,198
    6,461
    Good, that will save the freight charge.
    Dave's signature block indicates 171K miles.
  9. magruder
    145
    Colorado
    You are correct, my battery has lots of miles on it.
  10. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Hmmm, one thing i know is that the fan for the HV pack always kicks on randomly, thats a sign. and sorry = cry
  11. Flying White Dutchman
    4,374
    313
    sorry to hear this
    but at 171.000 miles the car is still running perfect?
    so you only have to replace the battery pack and you drive another 22k(replacement) and 171k = 149.000 miles ;-) for maybe a 500 dollar cost? of the replacement.
  12. magruder
    145
    Colorado
    Correct, the battery made it a long time, and it won't cost too much for a used battery. Perhaps my mpgs will go up as well.
  13. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    I would suggest checking salvage yards, not many places ship them cheaply though.
    I ended up picking up a 07 prius battery for 150, and a 05 prius battery for 250 to rebuild my 01 prius battery.
  14. Flying White Dutchman
    4,374
    313
    statultra
    how did that work out? or stil work in progress?
  15. efusco
    19,891
    1,191
    Nixa, MO
  16. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Hi Magruder, I was wondering if you've been able to test that the battery terminals and connections are still in good condition. I mean have you definitely ruled out a high resistance connection as a possible cause of the problem at this point?
  17. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Have you checked your 12 volt battery to see if it's good?
    Wayne
  18. magruder
    145
    Colorado
  19. magruder
    145
    Colorado
    Good question,
    A few months ago I did do this. The connections were nice and clean, and I did clean what little corrosion existed.
  20. magruder
    145
    Colorado
    The 12 volt battery was replaced with a factory battery in February.
