HV battery issues - ideas please
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by blarson8082, Feb 13, 2013.
  1. blarson8082
    blarson8082 Junior Member
    Arizona
    I'm a new member also. I have a 2005 and yesterday the master warning light came on. I went to the dealer and they checked it out. They showed me the voltage readings on the hybrid batteries and all were about 14.1 v except one which read about 0.5 v lower than the rest. The dealer determined that I needed to replace the hybrid batteries for a smooth $2800. Interestingly on my way home the warning lights all went out and everything seemed to be normal. Now I'm wondering what to do. Obviously I need a second opinion. Should I be concerned about the one cell's lower readings?
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Oh boy, where to start.
    The traction battery cells are 1.2VDC each - not 14.1. There are 168 NiMH cells in the 05 Prius assembled in 28 modules containing 6 cells in each module. The module voltage is 7.2VDC.
    What diagnostic trouble codes (DTC) were stored when they inspected your car? Did the stealership even bother to tell you what they were? They should have been listed on the work order you signed and paid for.
    If not, call them and ask for any/all DTCs they found and lettuce know what they are.
  3. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    You might want to consider if your regular 12v battery is in good condition. I am not a HV batt expert, but it is true that one bad module can bring down your Hv batt. Although it is theoretically possible to fix the one bad module, it is a lot of work to rebalance all of the cells, so normally, not done. If HV repalcement is deemed necessary, you could replace with a reconditioned batt, salvage batt or new Toyota batt, the latter being the most expensive option. Even a good quality reconditioned batt (Re-Involt.com) is probably going to run you $2000. Good luck.
    49,437
    $2800. from a dealer is a pretty good price. how many miles on her?
  5. usnavystgc
    3,159
    989
    Tucson, AZ
    If the warning lights have disappeared and not come back, their is a possibility that this was a temporary condition. If this were me, I would drive it and wait for the warning lights/DTC's to come back (consistently).
    Britprius likes this.
  6. khp
    khp Member
    76
    45
    SW Washington
    They are talking about block voltages (14 blocks per HV Battery)
    The battery ECU, which monitors two modules as a single battery block, detects the battery block voltage
    at a total of 14 locations.
  7. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    I second wjtracy's comment to check the 12V battery. If it's bad, all sorts of strange codes can be stored. The HV battery probably does have a bad cell, but that's a big hit to take before making sure that the 12V isn't the problem. I think it's about $2000 for a Reinvolt refurbished battery installed.
