HV Battery Losing Charge Quickly?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by heathenmom, Oct 10, 2017.
  1. heathenmom
    heathenmom New Member
    Georgia
    I bought a 2011 Prius with 113K miles on it 3 hours ago. Over the last week I test drove it twice, had it checked out by an independent mechanic, checked the carfax...everything seemed fine. The drive home was a less-than-20-mile mixture of stop and go traffic, highway driving, and idling in a parking lot. By the time I got home, the battery showed 7 lines of charge. I was home about an hour, then drove around the corner to my parents' (<1/8 mile). The car sat for about 10 minutes (shut off), then I drove back home. By the time I parked it, the battery had dropped to 2 lines.
    Is that kind of fluctuation normal?
    I'm not gonna lie...I'm scared to death the battery is going to end up junk and need to be replaced immediately.
    m.wynn likes this.
    49,508
    congrats and welcome!
    that is perfectly normal.:)
    all the best!(y)
  3. heathenmom
    Georgia
    THANK YOU!!!
    I'm so excited to have a Prius; I've wanted one forever.
    m.wynn, Raytheeagle and bisco like this.
    49,508
    that was how i felt 13 years ago. i'm still floating on cloud nine.:cool:
    m.wynn and heathenmom like this.
  5. ChapmanF
    15,665
    If you haven't bought a plug-in Prius, you've got a battery that wasn't ever even meant to hold more juice than needed to average out the demands on the gas engine while driving. So it will be up and down a lot in normal operation. Any judgment you make in the first three hours of driving will be too much influenced by every detail of those trips to tell you much.
    I'd be inclined to just enjoy the car, as long as it is driving as it should and not giving you any warnings.
    -Chap
    heathenmom likes this.
  6. heathenmom
    Georgia
    That makes sense; thanks!
  7. MelonPrius
    MelonPrius Senior Member
    823
    509
    Las Vegas
    Here's a tip: Fill your tank and set Trip A to measure the mpg for the entire tank. Use Trip B to measure your shorter trips.
    The mpg you get on a full tank will help identify if your battery is in good shape. The Trip B for daily trips for let you know how your speed and driving techniques impact your fuel economy.
  8. heathenmom
    Georgia
    I filled up this morning. After about 25 miles, the average is 53.6mpg. I'll keep my eye on things; hopefully it'll stay right around there.
    jerrymildred likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,515
    14,118
    Tampa, FL
    Not bad. Be aware that the car's computer is optimistic by 5-10%. You'll be more accurate by computing gallons at the pump versus odometer readings. But the car's computer is consistent enough to show trends.
    Prodigyplace likes this.
