HV Battery magically has a charge... How???
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ThatOddMan, Dec 27, 2021.
  1. ThatOddMan
    ThatOddMan Junior Member
    61
    24
    Alhambra, CA
    2014 Prius Plug-in
    Why did my PiP magically have its HV battery charged? It has less than 1 electrical mile when I parked it at work. But when I was about to go home. I found it charged to around 9 electric miles. But the lights on the dashboard were all lit. I powered off then on several times. Before it went a normal state but with EV automatically selected on drive mode. I had to manually set it back to gas use.
    I did tried to drive using EV mode after arriving at home. It drove on EV mode.
    Is there some sort of a leak?
    Part 01
    Part 02 (a weee bit longer video)
    Is it some sort of prototype charging from Toyota that I accidentally triggered on my PiP? (trying to stay positive since if HV battery breaks, then my PiP would become a paperweight).
    49,399
    sounds like a malfunctioning charge meter. i would bring it in to check for trouble codes
  3. drash
    drash Senior Member
    2,477
    1,252
    Upstate NY
    Have you ever changed your 12V? All of those lights on the right hand side seem to say either your 12V is low or you have a loose 12V cable.
    iPad ? Pro
    jerrymildred likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    THIS.
    And.....the circuitry that detects the State Of Charge in the HV battery is not perfect.
    It is not unusual for it to vary some like you have noticed.
    But maybe not that much.
    drash likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Agreed. Check the 12V and its connections. That might explain the erroneous battery indicator and those warning lights. Those caught my attention right away.
  6. ThatOddMan
    61
    24
    Alhambra, CA
    2014 Prius Plug-in
    I checked the service history. The battery installed seemed to be the original that my PiP came with from the factory. Unless a Toyota service department did not bother to put it on the record if the 12V battery was replaced.
    I checked the connection on the 12V battery. Nothing is lose.Weird thing is, I was able to drive on EV Mode. I guess, the charge I am seeing is some sort of a "reserve" charge that the HV battery has to keep it "alive". And I probably should not be using that "hidden" charge.
    But I am able to remove those Christmas lights on the dashboard using/activating the HV battery by pressing Start button several times while those dashboard lights are lit up.
    For Prius, is OEM battery still better than aftermarket?
    The pricing at Autozone (Duralast $210 and Optima Yellow Top $265) is too close to the advertised pricing from Toyota (part number 00544-21171-325); unless that part number is the incorrect one for my PiP's 12V battery.
    #6 ThatOddMan, Dec 30, 2021
  7. jerrymildred
    11,508
    14,109
    Tampa, FL
    In my opinion, the Toyota battery is the best one. If your battery lasted eight years, why would you change brands?
  8. sam spade 2
    7,035
    2,788
    2017 Prius c
    Even if you never plug it in, part of the HV battery is still used more or less like the much smaller one in a conventional hybrid model.
    But it will never come close to being "fully charged"......I assume.
    You should not be purposely trying to force the car to do something that it doesn't want to do......but some owners never quite understand that.
    So.....if your 12 V really is the original, you should change that first.
    And check the connections at the OTHER end of the main cables.
    Be sure that your new one is fully charged and then check the charging voltage while running.
    I would think that it would be good to plug it in and fully charge the battery every few months at least.
    Others will no doubt chime in and tell me how wrong I am. :rolleyes:
  9. drash
    drash Senior Member
    2,477
    1,252
    Upstate NY
    A degraded 12V battery can lead to many different issues, the least of which is not being able to start. The PiP is pretty much one big rolling computer (as are pretty much all Toyota/Lexus hybrids BTW), so a low 12V would affect sensors as well as other ECUs that rely on it's initial state. I used to use a technique called "stacking" on the PiP by keeping it in HV mode and liberally using brakes and lots of gas pedal manipulation to force it to store power. You may have inadvertently been stacking your PiP and when parked, the low 12V battery may have caused one of the ECUs to "lose" its stored EV state. The 12V isn't just used to power up the car, but it also runs a couple of post power off routines like depressurization of the brakes, turn off the DC/DC converter and run fans. This may have run the 12V to a limit where it caused an internal reset if a certain routine didn't finish. As your car ages these ECUs also age and on occasion they may become more sensitive to voltage changes. Your situation of constantly trying to restart seems to have finally tricked the DC/DC converter (which has its own ECU BTW) to finally kick on by giving multiple charges just out of range of a full restart.
    But "@sam spade 2" indicated you might want to charge it on occasion because that also turns on the DC/DC converter to charge the 12V as well.
  10. QuantumFireball
    QuantumFireball Active Member
    419
    267
    Ireland
    Sounds to me like the 12V battery is failing, leading to failed starts and ECU memory loss, so it's reporting inaccurate range. You say it was showing a range of 9 miles, but could you actually drive 9 miles in EV mode? I suspect not.
  11. SlidingBike
    SlidingBike Active Member
    171
    112
    Fremont, CA
    @ThatOddMan : What is the current state of your car fix? Did you change the 12V battery? Did it fix the issue?
    I am having the EXACT same issue since last month for my PiP(2013). Mine also the Original 12V battery came with the car, never changed. I just want to learn from you before replacing that battery. Any updates from your fix? Thank you in advance.
    BTW, thank you for all other forum members for sharing their thoughts around the issue.
    Mine shows 9 EV miles in the morning out of nowhere, it runs all these EV miles too.
    But as ThatOddMan's first video shows above, the xmas lights will keep for a good 10 min before the READY indicator gets on. I need to keep pushing the start button several times(as shown in the video above) to get the READY.
    Update: Looks like @ThatOddMan has changed his 12V battery but still having the SAME issue as of two weeks back
    #11 SlidingBike, Feb 6, 2022
  12. bisco
    49,399
    either way, it would be smart to change a 9 year old battery before you're left stranded, or carry a jump pack
    SlidingBike likes this.
  13. SlidingBike
    171
    112
    Fremont, CA
    I think you are right.. regardless, I should for for 12V make-over. Thanks Sir @bisco for that safe hint.
  14. sam spade 2
    7,035
    2,788
    2017 Prius c
    Makes no difference what experience anyone else has had.
    At 9 years old, you NEED a new battery.
  15. vvillovv
    vvillovv Senior Member
    3,615
    1,272
    NY
    I think, if the dash lights come on intermittently and the dash lights clear after a few cycles of - Power button On/Off -, that, unless there are permanent (Diagnostic Trouble Code) DTC's set already, you both, @ThatOddMan and @SlidingBike might want to get the DTC codes as they are set (with the dash lights on).
    And, I'm not saying there aren't already permanent DTC codes set in both of your cars. So, if it were happening to me, that would be the first thing I'd do, after I checked the 12volt batteries health with at very least a multimeter / voltmeter with the car Off, than in (Accessory - one Push of the Power button without pressing the brake pedal), than ( Ignition On - Press the Power button twice without pressing the brake pedal) , getting voltage readings for all three ...... You can go further by switching on the headlights, turning on the heater and or A/C and checking the voltage for each.
    DTC in cases like these will typically get much better results from those that know them (DTC's) best.
    Without DTC's everyone is giving educated guesses.
    #15 vvillovv, Feb 7, 2022
  16. SlidingBike
    171
    112
    Fremont, CA
    Update: @ThatOddMan has replied me that the replacement of 12V battery has fixed his issue. Now I am shopping around for the battery. Local Toyota Dealer doesnt have them in stock(No ETA of getting them), going to drive to another dealer bit far, its part# is 28800-21171, costs around $260(if I give my old battery back to them). Thanks.
  17. sam spade 2
    7,035
    2,788
    2017 Prius c
    While Prius batteries are often scarce, there is no reason that your new one MUST come from a Toyota dealer.
    Use the phone or the Internet. Check nearby auto parts stores, battery stores, tire stores and even WalMart.
    You might save some time and money.
  18. SlidingBike
    171
    112
    Fremont, CA
    Update: Replaced the 12V battery with Toyota (TruStart brand) Batt (total $272 with CA tax). Replaced it by myself using a youtube video. So far, the issue is not occuring again(will watch for it for few more days). All good.
    Thanks @ThatOddMan for well documenting the issue with videos and with your posting here, it really helped me. Thanks others for their right suggestion to replace the 12V brick.
    Side note: Also got my Cat Converter Shield installed (total cost $320 cash):
    #18 SlidingBike, Feb 11, 2022
  19. ThatOddMan
    61
    24
    Alhambra, CA
    2014 Prius Plug-in
    Oops.. my apologies for not responding here early. But saw your(?) comment on the YT video.
    Was not aware there were additional comments/responses on the discussion. I guess email notification is off.. probably.
    I still need to check the HV battery since I probably have used all that "reserved" battery charge that magically appeared before I replaced the 12V battery.
    Need to go to an EV charging station to charge the HV battery as apartment garage does not have any electric outlets.
    Data Daedalus likes this.
  20. Toyota lover
    Toyota lover New Member
    Uillinois
    I just replaced my 3rd 12 volt and the hybrid battery is ant fully charged it’s down 2 bars. I’m not sure what is causing the 12 volts to drain. I hAve 94,000 miles on a 2012 prius V.
    #20 Toyota lover, Mar 7, 2022
