HV battery module busbar nut torque value
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Jan 20, 2020.
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Could you please confirm this with me?
    Is it 48 in-lbs?
    I searched for it and wasn't able to find at more than one source which claims it is 48 in-lbs.
    I just want to make sure.
    Again I am talking about the little 8mm nuts that attaches the busbars to the each of the 28 battery modules in Gen3 HV battery pack.
    Thanks
  2. bunny45
    bunny45 New Member
    Germany
    Did you get the number from YouTube?
    I torqued my nuts to 5,5 Nm (48" lbs).
    It seems about right. Just make sure that you are using a real torque wrench and not some el-bozo cheapo POS.
    Are you only cleaning the busbars, or also reshuffling the cells?
  3. iskoos
    415
    254
    Orlando, FL
    We cleaning the busbars, replacing a few modules. With this job being so popular, I am surprised there aren't many online resources confirming the 48 in-lbs. I thought as soon as I typed this on Google, I would see many confirmation.
    So far I think only two websites confirmed the 48 in-lbs and many conflicting information. I am not so crazy about torqueing them to a certain number. I will get it right even without a torque wrench I am sure. I just wanted a uniformity since there are so many of them.
    So many videos on youtube telling you how to do it, almost none mentions the exact torque specs one needs to use.
    Thank you for your input.
  4. bunny45
    bunny45 New Member
    Germany
    You're replacing modules. How many miles you got?
    I reshuffled the modules at 80k miles. I've got less than 1/10th of a volt difference between the individual modules. I urge you to use a torque wrench.
    Even in winter I still get 51mpg calculated.
    I had the transaxle oil changed at 70k miles even though it is not mandated by Toyota here in Germany.
    Longinus876 and Peterhans like this.
  5. iskoos
    415
    254
    Orlando, FL
    It isn't my car currently, friend's car. He has a 2010 like mine with 160kmiles on it. He got so many modules that needs to be replaced. We only replaced two really bad ones. He has about 0.3volts difference between the lowest and highest voltage modules. We will see how much this helps.
    Yes torque wrench will be used. It would be silly not to use one if you have one...
  6. iskoos
    415
    254
    Orlando, FL
    May I get the 48 in-lbs confirmed from one other member at least please?
    Thanks
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,503
    Taylors, SC
    On 6mm bolts, full contact resistance and 60-90 degrees angular torque is often specified for aircraft-spacecraft assembly, instead of a frictional torque value.
    That's around 48-60 inch pounds.
    The angular torque method has been found to be more reliable in multiple industry studies, where the bolt tension has been measured from each method.
    iskoos likes this.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    yes....Toyota states 48 inch pounds for the module fasteners, which includes the positive/negative terminals and the mounting fasteners that thread into the bottom of the module. If you really want documentation, I can hunt it down in the repair manual, or you can just google torque requirements for that size fastener (M5)
    #8 TMR-JWAP, Jan 21, 2020
    Flyboy314, DB1961 and SFO like this.
  9. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    Just to eliminate any doubt....here you go...
    #9 TMR-JWAP, Jan 21, 2020
    DB1961, kc410, Shig and 6 others like this.
  10. iskoos
    415
    254
    Orlando, FL
    Thanks TMR, very much appreciated. I feel better now.
    Flyboy314 likes this.
  11. ChapmanF
    18,567
    I tend to regard the generic torque charts by fastener size to be a distant second in preference order to getting a specific torque for a specific fastener out of the repair manual.
    (Also, while on the subject of the repair manual, it also has a chart of generic torques by fastener size, up in the front matter, for reference in case there is no specific number given for a particular fastener. And that chart has different columns according to the strength of the fastener, and pictures explaining Toyota's markings that tell you the strength of each bolt or nut. That's an important detail to keep in mind when using the generic chart!)
    But the manual does give specific torques for nearly everything, so the generic chart is more of a last resort. The generic chart can't take into account all the variables: is this a stud threaded into a block of iron, or molded into a plastic battery module? What kind of washer is on it? Domed spring washers are not intended to be completely mashed into pale flattened versions of themselves. Etc.
  12. Mendel Leisk
    41,924
    Third gen Repair Manual excerpt (...Hybrid Battery Removal) has removal/install instruction, but maybe not bus bar nut torque. However, second gen RM excerpt (Hybrid Battery) has the bys bar nut torque values:
    jbmbenjamin, R_W and SFO like this.
  13. R_W
    R_W Member
    82
    25
    If I may clarify for my own piece of mind... the manual excerpt @Mendel Leisk posted which looks very similar to the page @TMR-JWAP photographed is labeled "2006 Prius Repair Manual". Are the torque specs the same for a 2010, Gen3?
    Like @iskoos, I've seen a couple of other numbers online, but none specific to a Gen3 original battery.
    Thanks
  14. Mendel Leisk
    41,924
    If I search my 3rd gen repair manual copy for:
    5.4 (55, 48 in.*lbf)
    or various portions of it, I'm getting no results.
    Maybe some of the battery pros will weigh in, but my hunch is you can't go wrong with 48 inch pounds. IIRC I've heard that mentioned here, for second or third gen. That's 4 foot pounds, very low torque. Do use a 1/4" drive torque wrench.
    I think there's even some sort of T-Wrench you can get, tuned to slip once torque reaches a value, say 48 inch pounds.
    R_W likes this.
  15. Mendel Leisk
    41,924
    R_W likes this.
  16. R_W
    R_W Member
    82
    25
    One of the videos I saw from a non-specialist said 60 in lbs for the Gen2 and one of the battery reconditioners said 44 in their video, which is why I wanted to ask. Don't want to snap one off, that's for sure.
    Thanks
  17. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    I've experimented with this. With only a nut on the terminal stud (no busbar linking to the next stud), it took about 110 inch pounds to damage the terminal stud. The stud actually twisted inside the module. 48 or 60, either will be just fine. Personally, I would not go less than 48.
    LukUsc, R_W, Raytheeagle and 2 others like this.
  18. Mendel Leisk
    41,924
    110 inch pounds is not that much, divide by 12 to get (almost) 10 foot pounds. You did this on a defunct cell?
  19. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    Yes, sometimes I used failed modules for fun experiments when I get bored.....
    I think it would take more torque to cause damage if the busbar were installed linking it to an adjacent module. As it was, the torque applied to the nut was effectively applied to base of the stud and the mechanical linkage behind it that attaches it to the internal busbars.
    Mendel Leisk and Raytheeagle like this.
  20. R_W
    R_W Member
    82
    25
    Please forgive me for extending this thread with the dumbest follow-up ever, but I'm trying to baby the battery. (I saw the post about the battery fire, when I was searching for an answer this afternoon)
    What size socket are the 56 specialty nuts holding the bus bars in place?
    While looking for the size, I tried a 5/16th in both a socket and a nut driver, but both had just a hair of play and because they are torqued on there, I wouldn't want to risk rounding them off, if that's not the right size. I've also tried a 9/32" but that was too small. Mathematically, the 7 and 8mm sockets missing from my set should be too small and too large, respectively. I went to a couple of stores this afternoon looking for a 19/64th or a 7.5mm to no avail.
    If I may ask, what size socket has everyone else used?
    Again, thanks! I appreciate the help.
