HV battery output comparison (new OEM vs. 12 year old, 170K)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mark010101, Jan 10, 2016.
  1. mark010101
    mark010101 Mark 04, 05, 08 Prius Owner
    65
    31
    East Central Illinois
    I did a battery comparison on a new OEM HV battery in a 2005 Prius vs. an original OEM HV battery in a 2004 Prius. I tested both under hard acceleration and braking situations.
    2004 Prius original OEM HV battery (170K miles on the car and the battery)
    graph: click here
    average = 17.2v, standard deviation = 0.9v, min = 14.3v, maximum = 18.3v, delta volts = 4.0v
    min = -72.2A, max = 98.0A, delta amps = 170.2A
    peak power output: 20.16 kW @ 66% SOC
    2005 Prius brand new OEM HV battery (108K miles on the car, ~ 100 miles on the battery)
    graph: click here
    average = 15.3v, standard deviation = 2.1v, min = 12.7v, max = 18.6v, delta volts = 6.0v
    min = -98.8A, max = 149.0A, delta amps = 247.8A
    peak power output: 26.99 kW @ 66.5% SOC
    I compared the new OEM 2005 HV battery power at peak (26.99 kW at 66.5% state of charge) vs. the old working 2004 HV battery at peak (20.16 kW at 66% state of charge). The old 2004 HV battery is showing a 41% degradation in power output vs. the new 2005 HV battery. This test was by no means scientific (two different cars, different acceleration and deceleration characteristics, and slightly different SOCs). I just gunned each car and then braked as hard as I could without tripping the hydraulic brakes.
    I read some where that the gen 2 HV battery outputs 20kW at 50% SOC. So this makes me wonder if my old battery is still performing fairly well (@ 20kW @ 66% SOC, not 50% SOC) and the new battery has design improvements that has boosted output (@ 66.5% SOC, not 50% SOC)? Thoughts anyone?
    As long as the 2004 HV battery modules are performing more or less the same on the voltage swings, no DTCs will be set.
    (Note I updated this section to more properly compare the two batteries based on peak power.)
    #1 mark010101, Jan 10, 2016
    m.wynn, S Keith and Dino33ca like this.
    51,682
    how do mpg's compare?
  3. mark010101
    65
    31
    Too early to tell. I need to get through several tanks of gas before I can say for sure. My off the cuff is that I think they are going to be similar since I rarely do hard acceleration.
  4. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Nicely Done and informative. It would be interesting on how the numbers will look or change on the new battery at specific intervals in time as we go.
  5. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    I'm particularly shocked at the deltaV on the new battery. I'm going to have to run some tests of my own on my freshly reconditioned Gen1 pack with Gen2 modules from 07-08.
    Was this with Techstream?
  6. mark010101
    65
    31
    Yes I used Techstream. I modified my comparison in the original post to compare peak power, not amperage. Based on that comparison, the old battery is down 41% from peak power of the new battery. This test was by no means scientific (two different cars, different acceleration and deceleration characteristics, and slightly different SOCs). I just gunned each car and then braked as hard as I could without tripping the hydraulic brakes.
    "I compared the new OEM 2005 HV battery power at peak (26.99 KW at 66.5% state of charge) vs. the old working 2004 HV battery (20.16 KW at 66% state of charge). The old 2004 battery is showing a 41% degradation in power output vs. the new 2005."
    #6 mark010101, Jan 11, 2016
  7. mark010101
    65
    31
    There are sensors in the car that controls when hydraulic brakes kick in (the yaw rate and deceleration sensors). If everything is normal the car switches to hydraulic brakes when stopping at speeds below 7 mph (if I remember correctly). I was able to determine the switching point by monitoring at the regeneration current going to the battery. I am sure there is a direct way to do this by monitoring the output of the yaw rate and deceleration sensors.
