HV Battery Temp Monitor
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Apr 14, 2024.
  1. AzusaPrius
    AzusaPrius Senior Member
    1,864
    812
    I am installing this to be used as a temp monitor for the HV battery air intake and exhaust.
    This way I do not have to have an app constantly running to watch the temp. 20240406_134829.jpeg Screenshot_2024-04-06-13-50-30-1.jpeg Screenshot_2024-04-06-13-51-10-1.jpeg 20240414_112525.jpeg
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,289
    336
    2013 Prius Plug-in
    what are you connecting to?
  3. AzusaPrius
    1,864
    812
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,159
    2,207
    Taylors, SC
    I would like to know how these temperatures compare to those of the HV battery measured by Techstream or the Scangauge 2.
  5. AzusaPrius
    1,864
    812
    The temps will not be exactly like the temp probes in the modules but it will just tell me the intake and exhaust air temps.
    That is all I need at a glance without an app running.
  6. Georgina Rudkus
    3,159
    2,207
    Taylors, SC
    No need for an app.
    The Scangauge 2 continuously gives a reading on the HV battery.
    john1701a likes this.
  7. AzusaPrius
    1,864
    812
    I am going with UltraGauge actually.
    Will be here on Thursday.
    Georgina Rudkus likes this.
  8. Georgina Rudkus
    3,159
    2,207
    Taylors, SC
    It will be interesting to see how the three temperatures compare. It will show how effective the cooling fan is.
    #8 Georgina Rudkus, Apr 15, 2024
    black_jmyntrn likes this.
  9. black_jmyntrn
    1,289
    336
    2013 Prius Plug-in
    yall fancy! I'm just gonna either epaper it or lcdf... I just havent seen the epaper at night. .
  10. TunahanS
    TunahanS New Member
    New york
    Boss i had a problem with my car . Can u help me . Its some different for me and i read your threads . I guess you this problem. I have 2010 gen 3 and i will change my transmission. I bought one but its 2012 v model transmission. Pipe inlets and outlets and cooler section are different. I need to cancel the cooler to install the v model. Will there be a problem with the car moving or starting when I do this? Finally, do I need to swap the power (electrical) cables? I would be glad if you help . I can give you my phone number to explain better.
  11. TunahanS
    TunahanS New Member
    New york
    I wrote you instagram dm . I need help boss. Thank you so much
  12. TunahanS
    TunahanS New Member
    New york
    I get your text . Thanks for help but i have some problem still . They said the problem was with the transmission. We changed it, but it still says check hybrid system when we press the power button to start the car. I connected it to the computer and cleared all the errors and it still doesn't work. There is no gas going to the engine. The car does not go into drive mode. What do you think the problem could be? Thanks again.
  13. rjparker
    rjparker Tu Humilde Sirviente
    7,925
    4,687
    Texas Hill Country
    A Prius v transaxle has different gearing in addition to the extra cooling. You need a standard Prius hatchback transaxle if you really needed one in the first place. They rarely fail but engine misfires or head gasket issues make them sound bad.
  14. AzusaPrius
    1,864
    812
    This modification has been discontinued.
    The temp wire needed to run to the intake fan was not long enough.
    I assumed they were the same length but they were not.
    Still had time to return it and got my money back.
