HV battery voltage difference Dr.Prius vs Torque Pro
Discussion in 'Gen 3 Prius Technical Discussion' started by DimitrisTS, May 23, 2025.
  1. DimitrisTS
    DimitrisTS Member
    30
    49
    Thessaloniki
    On my 2010 I have an Android head unit and torque pro always running. I am keeping an eye to block voltage difference as an indicator of battery wear and lately I am getting much higher values. Around 0.10 to 0.27 under load while it used to stay at 0.05 or for a short time up to 0.10 volt.
    So I started having Dr. Prius on all time to spot where the problem is. And there the voltage difference is significantly lower around 0.05 to 0.10. rarely it goes up to 0.15 for a second or two.
    So the question is why is there a difference between those two apps and which to trust?
    I also did a battery test and got a score of 88%.
  2. Tombukt2
    Tombukt2 Senior Member
    13,003
    2,330
    Durham NC
    They're just numerals on the other side of a decimal point hardly large amounts at all and on both of the apps the electricity in the batteries doing the same thing just with different numbers behind the decimal point or talking tenths here. 88% battery health I'd turn my attention to I don't know something else probably but I have no idea query the makers of the apps that would probably be the thing to do like you do when your phone's broken and when you see something on your screen that you own that you don't agree with you called the people that control the screen and the numbers
  3. ChapmanF
    18,224
    On the other hand, both apps should be asking the ECU in the car what the numbers are and getting digital values back, so a consistent, repeatable discrepancy in what the two apps show would suggest one of them (or both) could be doing some math wrong.
  4. DimitrisTS
    DimitrisTS Member
    30
    49
    Thessaloniki
    Thank you both for your input.
    Torque had an update at the end of February and maybe changed something?...
    If not, since torque gives a different picture than in the past, there must be a change in battery also
  5. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Dr Prius test results will fluctuate, sorry to pee in your Cheerios as one member here used to say.
  6. DimitrisTS
    DimitrisTS Member
    30
    49
    Thessaloniki
    Biggest sign of battery wear I guess is increased consumption. And I am not getting any. In winter I got around 5 l/100km (47mpg) and now with temperatures over 20c (68F) I get 4,5 (52mpg).
    I am just trying to find any early signs that would suggest it's a good idea to make a preventative battery rebalancing.
    The battery was replaced new by Toyota 6 years ago and made since, over 100000km (60k. miles).
  7. ASRDogman
    ASRDogman Senior Member
    7,599
    3,915
    Get the Prolong system and run the battery through the complete charge/discharge cycles.
    DimitrisTS likes this.
  8. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Shocked, no salty battery buy recommendation.
  9. ASRDogman
    7,599
    3,915
    That's because he wasn't looking for a new battery... There's nothing wrong with his yet.
    But when it's time, Sodium is the way to go! (y)
  10. HyBatteryMan
    HyBatteryMan New Member
    I can't answer your question exactly but I can tell you the following, it will surprise you, I bought myself a new hybrid battery, absolutely new, from a Toyota dealer and also connected a Dr Prius, the difference between the cells was 0.12V under load
  11. HyBatteryMan
    they have different codes-app and naturally there may be small bugs in applications that have this small difference and it is really insignificant because 00 does not exist even in new batteries
