HV battery voltage difference
Discussion in 'Generation 1 Prius Discussion' started by Joekingiam, Jan 24, 2011.
  1. Joekingiam
    Joekingiam Junior Member
    59
    Akron, Ohio
    Hello, I picked up another 01 Prius and checked the hv battery voltages. 36 modules are identical, 2 modules are less. Can a 3 volt difference set off the 3125 inverter code?
    Joe
  2. Politburo
    Politburo Active Member
    971
    208
  3. Joekingiam
    59
    Akron, Ohio
    Thanks for your reply,
    This manual lists the subcodes also, any ideas how I can find what the subcodes are?
    Joe
  4. ChapmanF
    18,571
    In the Classic Prius and ScanGaugeII thread, Vincent seems to have learned how they can be read with a ScanGaugeII which can be picked up at some auto parts retailers or from the PriusChat shop. A replacement cable that works with the classic Prius is available from the ScanGauge manufacturer upon request.
    -Chap
