HV Battery
Discussion in 'Gen 4 Prius Main Forum' started by opalbunny, Apr 11, 2025.
Tags:
  1. opalbunny
    opalbunny New Member
    Colorado
    I'm so sorry if this has been posted a million times before or is in the wrong place. I have searched the forums both here and Reddit trying to find solid information. I see a lot of information for Gen 2 & 3, but can't find info on Gen 4. Please direct me to the right place/info if this isn't it!
    Where the heck is everyone getting their HV batteries? I want prism, not cylinders (not greentec, green bean, or lithium ion). I want OEM, but it has been a fight to get a Toyota dealership to sell me one because "it's a liability," and "it requires specialized equipment." At this point, I'm okay with aftermarket, as long as they're new cells and not refills, because I'm seeing some of these known refurbed sites selling their assemblies at the same price as OEM new.
    I have a 2017 Prius, pushing 200K miles, and I can tell my HV battery is dying. I'd like to replace it before the triangle of death/hybrid system warning kicks in. Toyota has quoted me $5K (roughly) for them to do it. Also, they have been quite condescending when I call to ask if they will sell me one. No thanks. I am quite comfortable with DC electrical systems, and okay doing it myself.
    Thank you!
    amos likes this.
  2. Tideland Prius
    16,634
  3. frodoz737
    frodoz737 Top Wrench
    4,759
    2,529
    33
    I think if you press them a little harder your local will sell you a new OEM over the counter. I'm in Toyota's Gulf States Region and have no problem doing this.
    52,597
    call every dealer you're willing to drive to. some will, some won't. i couldn't recommend aftermarket.
    you should do a health check on your battery instead of trusting your gut
  5. amos
    amos Active Member
    376
    285
    los angeles
    Why do you think your battery will die soon? mine is lithium type 260k and it works like new.55mpg. Have you tried charge/ discharge cycles to your baterry very simple process
    #5 amos, Apr 20, 2025
  6. Prodigyplace
    12,704
    11,845
    Central Virginia
    Tince you have a Prius Two, it has the NiMH battery like older generations but with improved Nickel quality. Another option might be from a junkyard. I know my 2017 Prius Two with less than 57K miles is likely sitting somewhere in Virginia. Getting t-boned in the passenger door by a 4Runner did not affect the battery.
  7. cthorsman
    cthorsman Member
    75
    27
    Maryland
    Years ago I needed a battery for a gen 2 Prius. A local wholesale auto parts store offered me a much lower price than dealers in my area. He would not sell to me direct, only to a mechanic.
    Ended up buying one from a wreck in its case. Much easier, like plug and play. Did it myself.
  8. Prodigyplace
    12,704
    11,845
    Central Virginia
    Your best bet might be a wrecked Gen 4 Prius Two, or possibly a Prius One. My 2017 Prius Two is likely sitting in a junkyard somewhere. It had a good spare tire too. T-boning by a 4Runner was its demise.
    amos likes this.
