Hv Battery
Discussion in 'Gen 2 Prius Main Forum' started by Supertim, May 19, 2005.
  1. Supertim
    Supertim New Member
    Hello to all of you,,
    I am new here and am hoping that I am posting in the right place,, I have an 05 Prius that was in a wreck and then fixed,, the crash was light damage to the front of the car,, the air bags did not even pop. My problem is that the car was fixed and it will not move, I can only get it to go into neutral. The ICE will not start, I am somewhat mechanical and I seem to think that the HV battery is dead,, Is there any way to charge this battery,, Local Toyota dealers are really giving me a rough time and it is getting very expensive,, so I decided to give it a go myself, any help would be greatly appreciated,,
    Thanks
  2. yoda
    yoda Member
    116
    San Diego, Ca.
    Toyota SPECIFICALLY designed the Prius to NOT be "plugged in". I don't think that you can directly charge the HV battery without extensive modification.
    That said - the Prius IS designed so that it can be jump started if need be. The procedure IS in the manual. If you don't have your manual, post back here and I'll look it up for you.
    Yoda
  3. Tideland Prius
    16,159
    Does the MFD show any battery charge? It could be the 12v battery instead of the HV.
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    is the MIL on if so some one might have pulled the power plug on the HV battery. When it goes into neutral on the MFD on the energy screen how many bars are idicated on the battery?
  5. Supertim
    Supertim New Member
    The Hv Battery bars are only showing 1 bar and it is pink,, on the screen at the top there is a red square with a battery in it and another red square with a car with an exclamation point right in the middle. I have tried jumping it with no luck,, I have tried jumping it at both places that the manual says. I have read on other places in this forum that the hv battery is the one that actually starts the ICE. The Ice did start once when I first got the car,, but ran rough and died,, When I took car to dealer,, I had to pay special shipping for the hv battery charger to be shipped to my dealer.. The dealer told me that I needed the Inverter box(3000.00) and could not guarantee a fix. The car moved 4 ft when I picked it up and then died again,, I am guessing that they did not charge the hv battery long enough.. Sorry this is such a long post but just trying to give most of the details.. Thanks again for all of the help..
  6. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    "Local Toyota dealers are really giving me a rough time and it is getting very expensive"
    Oh boy... I'd love to hear the rest of this story!
    I mean, it's missing so many juicy details. Elmore Leonard could have written it! Did he get in a wreck or buy a wreck? Self repaired or dealer repaired? Why can't a dealer guarantee a fix?
    No offense, but most of us use a little trick called, "automobile insurance" to deal with issues like this.
  7. Frank Hudon
    4,147
    by the sounds of it they haven't charged the battery. If it was fully charged it'd be green and probaby near the top. The battery square and the car with the exclamation mark is a HV problem. You should have asked them for all the codes when they had the THHT connected.
  8. Anonymous
    Anonymous Guest
    Charging the HV battery is very difficult and only a handful of dedicated Toyota chargers exist (ie maybe only 2 or 3 Toyota dealers in the country will have one - more likely it will have to be flown over from Japan).
    Given the pink bar, however, I wouldn't rule out the possibility of another fault somewhere else. Could be as simple as a sensor somewhere disconnected or similar. You said the engine did start but ran roughly, that suggests to me that the HV battery had enough to start it, but something else (non-HV related) made it run rough and then shut it down. An emissions sensor or something? :?
  9. Frank Hudon
    4,147
    it's also a possibility that there is a problem in the fuel pump cutoff circuit. This activates in an accident to prevent a fuel fed fire.
  10. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Does AC compressor run? It doesn't need ICE, but uses the HV battery.
    It could be the service plug with the fuse was not installed back into the battery. The HV Battery ECU could still detect the voltage across each segment block. But then, it wouldn't have been able to start ICE.
    If plug is in place, then have the battery charged. Display should show blue or green. Keep an eye on it as you try to run the car, or even just run the AC. If it is not a hot day and the compressor is not running fast (you can certainly tell, it is a bit loud), and the SOC drops quickly (less than a minute), you have a bad battery.
    DTCs would help the diagnosis. The battery ECU can detect problems with individual battery blocks.
  11. DanMan32
    3,799
    26
    Tampa Bay, FL
    In a wreck, then fixed. Are you saying you bought the car as salvage to try and refurbish it, or you were in the accident? If you owned it during the accident, how come insurance is not involved?
  12. jtmhog
    jtmhog Member
    151
    Some Tips:
    1) Go back to the dealer with the HV battery charger and determine if the battery will accept the charge; make sure there is not a connector problem; assuming the MFD is working, a fully charged battery will be all green; no green-no charge-bad battery. Junkyard price abt $800.00.
    2) This is general guidance since I haven't done it. Measure voltage(V) at HV battery; measure battery at inverter; should be the same; have some one try to start car, if nothing happens, measure V going to motor/generator that starts the engine. This may be 500V. Don't kill yourself. You may need shop manual and may have to remove cover of inverter to gain access to the correct connector. If green light is on in power button and no V out of inverter-bad inverter. Get it fixed or buy replacement from junkyard. BE CAREFUL OF HIGH VOLTAGE
    3) If you buy these big ticket items and it still doesn't start, pay someone to burn or steal it.
  13. DanMan32
    3,799
    26
    Tampa Bay, FL
    It would be difficult to measure voltage at the motors, as they are 3 phase synchronous AC motors.
    The inverter and HV ECU does extensive monitoring and would cough up DTCs if there are problems with the inverter and possibly even the motor.
  14. Frank Hudon
    4,147
    Dan you just measure the voltage across the three legs.
  15. jeromep
    jeromep Member
    827
    Eastern Washington State
    The system has to be spitting codes out like crazy. Why hasn't the dealer that is working on it pulled the codes to see what the car is complaining about?
    If the dealer you are working with is clueless find another and get your car towed there. I'm highly inclined to believe that there is an incompetent factor someplace in the repair chain of events.
    Everyone in the post who has said, if you see any bars on the MFD, the battery has voltage and should be just fine. This doesn't sound like a battery issue to me, it sounds like a sensor or other engine compartment issue.
  16. Supertim
    Supertim New Member
  17. Supertim
    Supertim New Member
    Sorry about the last post ,, But I had a long list of things and I pushed the wrong keys.. I am going to test the hv battery for voltage and get back to you,, Thanks for all of the help..
  18. Supertim
    Supertim New Member
    The hv battery has 175 volts in it and when you try to start the car the solenoids click and the voltage on the other side is about 125.. Not sure if this is enough to try to start the car,, ( They should install a pull start on the motor and this would solve everything).. The car was bought at a salvage auction and we fixed it,, All factory toyota parts,, But nothing electrical was damaged,, It was a hood, radiator, fender ,rad support and the all expensive headlights.. I actually talked to the woman that wrecked the car today and she said that she was going 20 mph and clipped a taxi,, strange thing is she drove the car home!!!!! I am almost thinking that somebody put a faulty part on this thing somewhere.. Toyota wont warranty because of the salvage.. This car is beautiful and I would really like to get it going,, but to put another 3000 for an Invertor box(like toyota said ) and it may not work...I am not sure..
  19. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    <div class='quotetop'>QUOTE(Supertim\";p=\"91299)</div>
    If the car sits for a few months, the HV battery will be too low to start the car. 125 V sure sounds low. I think you need to try to get a dealer to condition the battery for you. (Of course, it's just a guess.)
  20. DanMan32
    3,799
    26
    Tampa Bay, FL
    125 is WAY too low. If you can somehow inject 206V or so DC into there, maybe you can get ICE going to charge the battery, assuming the HV electrical is sound.
    Perhaps 17 lantern or gel cell batteries?
    It would help if you could get a hold of a THHT at least for a while. I understand they run about 4 grand with the programming.
    Where are you at? Maybe someone near you could help out. I'd love a challenge like this. I have a few ideas to try and revive the battery pack, either as a whole or one block at a time. After all, the battery ECU has to have access to both terminals of each block in order to monitor its voltage.
