HV ECU vs. Hybrid Battery - Which is bad?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by simonman, Dec 28, 2011.
  1. simonman
    simonman Junior Member
    Grand Rapids, Michigan
    I have a 2007 prius with 140,000 miles. Never had one thing go wrong with it.
    Recently, the Toyota dealer when replacing the tires "fixed" the hybrid cooling pump issue and flashed the computer (I am not sure why any software revision was involved). They did the fix without my consent or knowledge. Now, 2 weeks later, I have several warning icons on my dash. The dealer says I need a new battery for $3300. My question is, how do I really know if the battery is bad or if it is the HV ECU (charge controller)? The battery appears near dead in the morning but about 5 minutes down the road it will be charged up to the max for the duration of my drive. The car has a lack of power. Any help would be GREATLY appreciated. I was not able to find my answer in the forum anywhere.....
  2. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    720
    Boulder Hybids, Boulder, CO
    Tell them to flash the Battery ECU back to where it was. If they won't do it, call Toyota corporate and explain what happened after the dealer "upgraded" the computer. Try and get corporate to replace battery under warranty. If that doesn't solve your problem, get a good used battery for $600-$800. Not too hard to install for most mechanics and DIYers....and very safe to work on once you remove the orange service plug.
    chronon likes this.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  4. 3prongpaul
    954
    720
    At this point in time most lowish mileage Gen2 "junkyard batteries" are still very good, especially if the car was in a front end collision. Any 2004-2009 battery will work in your car. No need to have your Gen2 battery rebuilt.
    Your cheapest solution would be to source a used Gen2 battery yourself from AutoBeYours, AdoptAPart or similar then have someone locally install it.
    If you had a gen1 Prius (2001-2003), that would be a different story. For Gen1 prius you want a rebuilt battery or at least one with a decent warranty in case it doesn't work out...most junkyard Gen1 batteries are in fact junk.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    I'm not aware of any reflash available for '07. I'm not sure it is even possible to reflash the battery ECU. If you could scan and post a copy of the invoice, then we could comment further. What you describe has all the hallmarks of HV battery failure. You can try the "you serviced my car and messed up something" approach, but it will be very difficult. Yours has the combination of age and mileage for when failure becomes a possibility.
    If you can pull a battery from a fresh wreck, <6 months, it should just work.
  6. richard schumacher
    7,663
    1,038
    United States
    It is common when replacing the pump to not get all the air out of the loop; the dealer who did mine needed to re-do it, and we've read of multiple cases here. It could very well be as simple as that causing the inverter to overheat. (Yeah, I know, it's winter, but if it's not getting any coolant...) Before spending thousands tell that dealer, or a different one, to try again. Given the "let us sell you a new battery" advice I'd lean toward a different dealer. But do it soon, because an un-cooled inverter can destroy itself.
  7. mehanson
    mehanson ElectroMechanical engineer
    Massachusetts
    2001 Prius
    I have a gen 1 (purchased in April 2000) prius which just got the HV! warning and codes P3000 and P3006. In a static test of the battery at a dealer this Friday the blocks of cells were within 0.7V of each other (less than the 1.2V criterion). The diagnostic chart the tech was using indicated that the ECU needs replacing.
    I'm not convinced that we've tested it appropriately.
    I see that the ECU does control the flow of energy from the battery to the motor/generators, so perhaps it's not a connector issue. My first guess was to 'wiggle' the connectors (not high voltage, but control signals) that relate to the HV ECU. Often in computer systems it's the connectors that cause failures.
    Any thoughts?
  8. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    1.2V is the most definitive, because it means for sure that a cell has gone bad. But 0.7V from high to low at rest is a very bad sign. .06V/cell is a huge difference in NiMH state of charge, as much as 50%. In normal conditions, the difference is 0.1V or less. Your ECU is fine, and your battery needs to be repaired or replaced. I do not recommend replacing a Gen 1 battery with another one from a junkyard. You need to look at ReInvolt.com or options along those lines.
  9. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If it turns out that you need an HV battery ECU, I have one that I would be willing to sell.
    JeffD
  10. mehanson
    Massachusetts
    2001 Prius
    How did you end up with an extra ECU?
    But more to the original point, in Massachusetts the dealers say the hybrid system warrantee is for 150K miles and 10 years. I'm not sure about Michigan, but perhaps the repair is covered?
    I have a Gen 1, 2001 prius that is showing p3000 and p3006. I've not been satisfied with the Toyota dealer service department's diagnostic methods so far, but will work with them some more on it. In driving the car I'm wondering if the problem I'm seeing, which looks more like an ECU malfunction than a battery failure, might be due to corrosion on the ECU connectors that is garbling data occasionally. Any thoughts? In my experience as a mechanical engineer and computer systems designer it's often the connectors that cause system malfunctions. However, beyond resetting the connectors, I don't have a good strategy for checking this.
  11. jdenenberg
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When the HV battery failed in my 2004 Prius at 195,000 miles, I replaced it with a ReInVolt ($2000 installed). I was not required to send them my old battery, so I disassembled it and determined that only one module had a bad cell. After a little research I purchased some equipment, rebalanced the 27 good modules and have sold all of them (clearing better than $25 each :) ) and still have the remaining battery parts at home.
    JeffD
  12. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Pull the battery out and take the cover off. That will tell the story. On a car with your age and mileage, even though the flowchart for P3006 says to replace the ECU, I'd give it 99% that it is the pack or corrosion at the sense wires. The only way to know for sure is to pull it out and take it apart. The traction battery autopsy thread is a good source of information.
    http://priuschat.com/forums/generation-1-prius-discussion/84017-nhw11-traction-battery-autopsy.html
    Rob Hutchins likes this.
  13. Flying White Dutchman
    4,374
    313
    :confused: 0,1 volt or less?
    o wait you mean 100milivolts? and ,06 is 60 milivolts?
    yes that high....
    just checking if its not 0,006volts and so 6 milivolts what is normal.:confused:
  14. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    The ECU tries to keep a 0.1V or less balance throughout the pack. The pack is managed in groups of 14 cells/2 modules. Each cell has 1.2V nominal. Hence the average across 14 cells is 0.7V/12 ~= 0.06V. If you look at SoC curves for 1.2V NiMH cells, you'll see that 0.06V is approximately the difference between 80% and 40% -- full and empty if you are a Prius.
  15. no trust
    no trust Junior Member
    46
    Powhatan, VA
    you always have the do it yourself rebuild option! I rebuilt my HV battery with two of Jeffs modules, over 10000 miles with no problems , cost $70. To update you Seilerts , the modules now read 7.51v and 7.36v untouched from the rebuild , the 7.36 module was the one that stood out from the rest.
    2 people like this.
  16. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Did we ever figure out if it was the battery or ECU?
  17. jholtcictnic
    jholtcictnic New Member
    US
    Jeff, I have a 2012 Prius C with 113k and the Hybrid Warning Light came on in Jan. It would not start so I had it towed to the dealership here in Maine. After 1 week, they said they did not know what was wrong, reset the warning light and sent me on my way with a $300 bill but said it would likely happen again. This Monday morning, it would not start. Now I have 115k miles. Had a local Toyota guy look at it and he suspects it is the ECU. Would the one you are selling fit in my Prius?
    Merged back to back posts @jholtcictnic. Please use multi quote, Thanks.
    Toyota told me that the Hybrid system is covered for 150k miles in California, and 100k miles in all other 49 states.
    #17 jholtcictnic, Mar 29, 2017
  18. jdenenberg
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My ECU was from a 2004 Prius Hatchback and was sold back then. It probably would have been incompatible with your "c" anyway.
    To get your Prius running, disconnect the 12v battery for a minute and then reconnect it. That should reset the codes that are preventing it from starting. Where in the US are you located. There are several independent Prius repair shops around the country that are typically better (and less expensive) at diagnosing a hybrid problem than the dealer.
    JeffD
    jholtcictnic likes this.
  19. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    jholt,
    I have (2) 2013 Prius C hybrid battery cases/carcasses in my garage. I used the modules to rebuild the battery pack in my son's 2005 Prius. The remainder of the parts are still there. I can probably hook you up with what you need, I'll be back there in about 2 hours. I'll check it out and see what I have.
    OK, the 'C' hybrid batteries have only one module, labelled as a voltage sensor, not exactly what I'm used to seeing for an ECU, but similar to Gen 3, unless we're talking about the same thing or the ECU is separate from the battery. I'm just not very familiar with the C model. My part number is 89892-52010 IMG_8705[1].JPG .
    SFO and jholtcictnic like this.
  20. jholtcictnic
    US
    Thank you. I am in Maine. You're right, now I am working with a local independent shop owner specializing in Toyota, whom I am finding much more helpful than my Maine Toyota dealership, or even Toyota corporate. Since I bought my C in Florida, Maine seems to be in no rush to help me get back on the road.
    So the engine and all other components work, it just will not start / my READY light will not come on. There is no code, no communication that pops up about what exactly is wrong. Now we are looking at replacing the ECU, perhaps ECU and battery. Does that sound right?
    I have been the biggest advocate for Prius for 5 years. If you asked me right now I do not think I would ever buy a Prius again. I am just sick that the hybrid system died 13k out of warranty. This forum is so helpful, thank you.
