Hv fan cleaned and now triangle light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Zain malik, Aug 10, 2018.
  1. Zain malik
    Zain malik New Member
    Pakistan
    I cleaned hv battery fan and re installed it again and now it says check hybrid system.
    All connectors are good and properly installed
    What could be the reason for triangle.
    Fan works well when i checked on 12v but when the car starts the fan stops working
    Please help
    49,507
    welcome!
    you pulled it all apart after getting the error message, and all connections were good?
  3. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    did you hit the fan with a dust can while power leads were connected?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    If you have a way to read the codes, you’ll see what the root of the message is;).
    Otherwise check to make sure the connection of the fan is tight as there has been more than one person who thought it was tight and it wasn’t :(.
    Good luck and keep us posted (y).
