HV nd ECU
Discussion in 'Gen 2 Prius Technical Discussion' started by haider, Jul 13, 2013.
  1. haider
    haider Junior Member
    37
    Lahore, Pakistan
    2012 Aqua
    I
    I was driving my car fine suddenly ac stopped cooling nd these signs appeared. I am uploading the pictures. Please help if anyone can.
  2. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    720
    Boulder Hybids, Boulder, CO
    Could be the inverter coolant pump died, inverter overheated, this shuts off the AC. You need a scanner to retrieve the error codes, or turn on the car and feel for fluid movement in the coolant hoses that leave the inverter. (one on the reservoir the other is low but on same side as reservoir).
    haider likes this.
  3. haider
    37
    Lahore, Pakistan
    2012 Aqua
    I
    I have arranged for a scanner. I will try to get the codes in the morning. I will share with you guys.
  4. haider
    37
    Lahore, Pakistan
    2012 Aqua
    I
    I will.check for the movement of th coolant as well. There are two different fluids? One which runs in the radiator and cools the engine? And there is another fluid and pump which circulates in?
  5. haider
    37
    Lahore, Pakistan
    2012 Aqua
    I
    There is no turbulence. I just started my car and put the car to ready mode and there wasn't any turbulence.
  6. haider
    37
    Lahore, Pakistan
    2012 Aqua
    I
    I have got my car checked. Its code is PA093...inverter pump error. Need to replace it? Can it be repaired? Any information about that it can be replace under Toyota Limited Service Campaign of replacing the faulty inverter pump?
