HV Nut Removal when STUCK
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hitech51, Mar 26, 2021.
Tags:
  1. Hitech51
    Hitech51 Junior Member
    Houston, Tx
    2013 Prius v wagon
    Got the HV battery out to recondition it ...but... 14 Nuts will not come loose from the battery modules....
    Tried 3 sockets and even ground down one to make it fit better but no go...
    Tried vise grips, and unfreezing liquid spray, etc....
    Any suggestions ???
    #1 Hitech51, Mar 26, 2021
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
  3. Hitech51
    Houston, Tx
    2013 Prius v wagon
    Drill out a nut that is connected to the bolt going into the plastic battery module ??? Explain ?
  4. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    See if this helps:
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes, I would take that as yet another (14) sign(s) it's time for a new battery.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    A "light duty" impact tool might help a lot.
    Giving it a few shots in BOTH directions will often break them loose.
    There is a "nut breaker" device that can be quite useful but not in a tight space like the picture shows.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    Option 1: use a small cut off wheel on a dremel tool to slice away part of the nut then use vice grips to break what's left.
    Option 2: replace the battery- get a used pack and recondition that
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    14 nuts on a 2013 HV battery will not come loose? Is this a previously repaired/worked on battery?
  9. Hitech51
    Houston, Tx
    2013 Prius v wagon
    Yes, it was taken apart as to nuts and the bars, cleaned and greased. Dr prius suggested replacement of a few modules but we want to cycle them first to see the real capacity of each. the voltage is btw 7.8 and 7.85 for each at this time....
    Broke one socket tool set from HomeDepot and now ready to try the one from AutoZone.... Lastly will cut a crease in the nut....
