HVAC control panel acting weird
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by trentofdestiny, Jul 15, 2019.
  1. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Today when I left work the HVAC was off from my trip to work. I pressed the auto button and maybe slipped and hit the recirc button at the same time. All the LCD segments came on and started flashing. Then it read 00 degrees. I had to turn the car off and back on to make it work. I could not reproduce it again by hitting two buttons at the same time. What was going on? Was it a self test mode? It was 90 degrees out today, which is pretty hot, even for here.
  2. ChapmanF
    18,562
    AUTO + RECIRC together (usually right when you are powering the car on) is exactly the combo to get the HVAC diags.
  3. trentofdestiny
    1,104
    227
    Harrisburg, PA
    But the car was already on for a few seconds before I tried to activate the HVAC. And I couldn't reproduce it but just tapping the buttons.
    iPhone ?
  4. ChapmanF
    18,562
    Just went out and tried it on mine. Seems to work if the two buttons are pressed any time within five seconds or so after powering the car on.
  5. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I see. I will try it tomorrow as my car is outside rather than in the garage. Good to know though. Thanks! Does it exit the mode on its own?
    iPhone ?
  6. ChapmanF
    18,562
    When you power the car off, or press the HVAC off button.
