HVAC Question................. Is AUTO the best setting?
Discussion in 'Gen 4 Prius Main Forum' started by atterbury90, Nov 27, 2019.
  1. atterbury90
    atterbury90 Junior Member
    52
    22
    SE Pennsylvania
    2022 Prius
    XLE AWD-e
    When using heat or a/c, is there something the Auto button selection does that is more economical, or is it just a convenient way to maintain the desired temperature?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Auto is convenient as all get out. While it's not THE most economical, it's far from the least economical. Most of the time, I set my desired temperature and leave it on auto. This time of year in FL, I usually have it off altogether or might just run the fan on speed two with the air conditioner off. If it's chilly enough and my wife is with me, I'll put it back on auto if she's not satisfied with the seat heater. And then there's the odd time when I need to blow some condensation off the windshield.
    But those are in the minority over the span of the year.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I've only ever used AUTO with RECirculate. Adjust the temperature occasionally.
    AND if I want to cool the car quickly, I press this - which brings in vents to all positions:
    Not sure, in USA, yours might look like this:eek::
    52,378
    i've never used auto, i can't stand the loss of control :whistle:
    krmcg and alanclarkeau like this.
  5. alanclarkeau
    7,045
    7,593
    It's the only way to get Gen 4 A/C working.
  6. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    alanclarkeau,
    And here in the USA our water goes down the drain clockwise whereas your OZ water goes down counter-clockwise.
    alanclarkeau likes this.
  7. bisco
    52,378
    really? count me out. no more temp gauge, a/c button and manual fan control?
  8. alanclarkeau
    7,045
    7,593
    They're there, but it won't A/C unless you press the AUTO button - you can over-ride it by turning A/C off - then AUTO isn't really auto, and change the fan control, but it works that out well itself. AUTO won't interfere with Recirc/Fresh though.
    But as far as I know, there is no way of putting the A/C on without pressing AUTO. The manual only talks about the:
    No Manual.
  9. bisco
    52,378
    ugh. i guess the that makes the o/p's question a moot point
  10. alanclarkeau
    7,045
    7,593
    I far prefer a Manual transmission
  11. jerrymildred
    11,517
    14,157
    Tampa, FL
    Different models have different control layouts, but I think they work about the same. My Prime Premium is radically different in user interface than most Gen 4 models, but works the same way.
    Back to the original question, though, Auto is by far the most convenient. Like @alanclarkeau, I keep mine mostly on Auto with recirc. But I often override that. One thing I do a lot here in the summer is turn off recirc until the cabin cools down to close to the same temperature as outside. It's quicker AND more comfortable to cool 95F air than 135F air. Or I'll increase fan speed to suit my wife. Both of those will turn off the "Auto" indicator.
    davecook89t and alanclarkeau like this.
  12. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    I like the auto feature especially in the winter months. I usually hit auto then deselect the AC unless I want it. The nice thing in cold weather is the fan will not blast you with cold air. The auto waits until the engine is warming and gradually brings up the fan as warm air is available. SO much more comfortable. I set it that way and forget it. It will also modulate the air where needed. Then I add the AC when needed only on a hot day. I have happily used it that on my last 2 Prius.
    Tyfly and davecook89t like this.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And I doubt that it has any measurable impact on economy, versus doing the settings manually.
    In every car I've ever owned that has that setting, it stays on AUTO most of the time and just the temp setting gets moved up or down a bit.
    The exception to that, as you mentioned, is when the outside temp is around 70; some manual adjustment might be necessary.
  14. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Really? I have had my car set AUTO for my first summer, but this summer I have kept AUTO off most of the time. If you have AUTO off, but A/C on, wouldn't it turn on the A/C for cooling? I sware I could get cold air coming out of the vent using that setting, but I am not 100% sure. Maybe PRIME is different?
    At least under my use case, keeping the PRIME in AUTO during winter had a very big hit on EV range due to heavy reliance on the heat pump for heating. The car tries so hard to keep the ICE off and use up the battery by running the heat pump. It turned out switching to HV manually and keeping the climate control manually set to low fan speed is doing a much better job in saving EV range for me. Yeah, for many places where running EV is much cheaper may benefit by keeping the climate control in AUTO and minimizing ICE use is economical, but for where I live, gas is cheaper than electricity, the AUTO climate setting cost me more on charging cost.
    krmcg likes this.
  15. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I've noticed that using AUTO in winter months (or like now) it will actually keep my car running while stopped at a light. As soon as I hit the off button the ICE shuts down. Mine is a Prius C however. Not sure if that makes a difference.
  16. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    AUTO is the most convenient setting since it adjusts the fan and vent settings automatically to keep the cabin at your desired temperature. The AC button is independent of the AUTO button in the sense that pushing it ON or OFF will not change the AUTO setting. You can still remain in AUTO with the AC light off. Selecting a manual vent or fan setting will turn the AUTO light off.
  17. Mendel Leisk
    41,892
    On our 3rd gen, the ONLY way to turn the system "on" is to push "AUTO". A request for Toyota: how about an "ON" switch? Perhaps it could even bring it back on, as you had it it set previously?
    Heady stuff...:rolleyes:
  18. bisco
    52,378
    really? i just turn the fan on and the system comes on. i can either raise the temp for heat, or press the a/c button for cool. 'auto' never comes on.
    maybe they updated 2012?
    Merkey and Mendel Leisk like this.
  19. Mendel Leisk
    41,892
    Really? That could be an "easter egg" I've missed (for 9 years), will try that. I know on our Civic Hybrid, if I'd turned it "OFF", then hit the fan speed up it would restore it, as it was. Seems to me I tried that on the Prius, no luck. Could be a CDN spec thing too. But yeah I'll give it a try.
  20. Tideland Prius
    16,615
    Couldn't you just increase the fan speed from zero? That should turn it on in manual mode.
