HWY MPG for the 2010 Prius. PLEASE HELP!
Discussion in 'Gen 3 Prius Main Forum' started by Indyking, May 28, 2009.
  1. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Hi everyone, this has probably been addressed somewhere in this forum but I couldn't find detailed information about it. I'm considering buying a 2010 Pius (III) to accommodate my new commute needs, which is driving 3000 miles per month, mostly highway (95% HWY). I usually cruise at 80 MPH, mostly flat roads. I love the new Prius but I'm questioning how good it would perform and what would be the MPG at such high speed. Does anyone know? Any information will be highly appreciated!!!
  2. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    What part of the country are you located in?
  3. jsharpe
    jsharpe Member
    111
    26
    Theoretically the 2010 should be even better, but my son's 2007 typically averages high mid to high 40's at the speeds you reference (and substantially above but I have know idea who was driving that fast :), even when throwing in some wind, mountain passes, and altitudes averaging 8-10K ft. This compares favorably with TDI powered cars which are often considered the highway mileage kings and is about the worst possible location/use for the Prius' hybrid system which really targets lower speed stop and go. The bottom line is you will be hard pressed to do better, even for mostly highway driving.
  4. Indyking
    1,280
    Hi Danny! I'm located in the Midwest, will be driving from Indiana to Wisconsin once a week round trip for a total of almost 1000 miles per week. Most of the drive is really flat and will be cruising steady at 80mph for most part. What do you think?
  5. Indyking
    1,280
    thanks for your reply! That's exactly my dilemma, 2010 Prius or 2009 Jetta TDI? It would make a lot more sense go with the Jetta based on my needs (3000 miles/month, 95% flat Highway driving) but a similarly priced 2010 Prius (Prius III) is better equipped with a much more refined/hi tech interior. The true cost of ownership is similar in both over a period of 5 years, but I suspect in 5 years, a 2010 Prius with 180,000 miles will have a dead battery in need for replacement (very expensive) while the TDI engine of the Jetta is claimed to run nicely with minimal service until 300,000 miles. Also no question the Jetta TDI is a lot more fun to drive than the Prius because of the high torque of those engine types (no comparison there). So, I'm not sure what I should invest on, that's why I'm trying to get a more accurate estimate of the HWY MPG for the Prius to help me decide. The 09 Jetta TDI gets around 40MPG or less cruising at 80MPH from what I learned in other forums. Any thoughts?
  6. GreenWithEnvy
    GreenWithEnvy New Member
    81
    SE Wisconsin
    I think you may get better mileage (close to 50 mpg) with the TDI once broken in, but I'm not sure where you heard that about minimal service. The TDI service is expensive, and the timing belt replacement alone is $400-800 (VW vs. independant), not including the tensioner and water pump (another $100+). Interval varies with engine, but it's at least every 100k and I've read up to every 40k. It was a deal breaker for me, but I drive mostly city miles.
  7. Indyking
    1,280
    The VW dealer told me the timing belt replacement is due every 120K (not 40K!) and it does not cost as much as you say. The maintenance cost when calculating true cost of ownership in the Edmunds website (TCO) is slightly lower in the 09 Jetta compared to the 2010 Prius, and it does not take into consideration battery replacement in the Prius, which can cost anything from 5-7K. Not sure when battery should be replaced though, anybody? I heard, every 150,000 miles, so if that’s true, the Prius costs a lot more that the Jetta in the long run, especially considering that Diesel engines have very long lifespan.
  8. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    250k+ for battery... modern diesels have a lot of things that break over the long time.
    Plus you will be paying more for gas as diesel is more expensive.
    Also check residual values if you are concerned for the long term, not sure what they are.
  9. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Edmunds TCO for Prius is 2x higher than my ownership experience of 96k miles.
    The HV battery should last 300k miles if you do mostly highway driving. The brand new replacement pack costs $2k plus the labor today. When your warranty expires in 10 years, the pack will cost even less due to popularity and mass production.
    Diesel emission equipment replacement/repair will cost a lot once the warranty expire as well. Jetta's transmission may need to be replaced and it's warranty is just 3-5 years. There are a lot of moving parts and it requires maintenance (unlike HV battery). Think about that.
    2010 Prius highway MPG should match or beat Jetta TDI. However with Prius, you get the benefit of superior city MPG. Remember, highway can have traffic jams and congestions as well! Prius will do 3-4x better MPG than the Jetta in those situations.
    It takes a bit of aquired taste to fully appreciate hybrid exclusive premium features such as EV driving, Eco mode, Power Mode, regen-brake, fast cabin warmth, jet-like smooth acceleration, high torque responsive electric motor, etc... Jetta is lacking those features that you will eventually learn to enjoy!
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  12. Steve Cebu
    Steve Cebu New Member
    523
    59
    Concord, NH
    Sorry to disagree but I spoke with the VW sales manager of the dealership here and they said Timing Belt at 60K miles! No mistake as I asked 3 times.
    He said they also replace the waterpump at the same time. So I guess it depends on what dealer you talk to.
    The fact that I hear so many different stories about their maintainance worries me.
  13. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    I'd never buy anothe VW. I used to own a 2001 Beetle. Nice designs, but poor reliablilty. I put way too much out-of-pocket money into that car keeping it running, even though I bought it new.
    Consumer Reports also confirms their poor reliability
    My daughter-in-law had a Jetta. Many problems with that car while she owned it. Final deathwish of that vehicle: she brought it to a VW dealership for routine maintenance. 15 minutes after she left, she got a call from the dealership: the engine compartment had spontaneously burst into flames while the car sat parked in the dealer's lot!! It was totalled.
  14. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    If you are driving 3000 miles/mo on flat roads, you might consider the Prius V with lane keep assist and adaptive cruise control in case you start to fall asleep driving.:)
    Roy
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    The 2010 Prius revs 300 RPM lower with the larger 1.8 liter gas engine. eCVT revs at extremely low RPM on the highway. The "gearing" is taller than 6 speed tranny in the Corvette. Check out this video:
    [ame=http://video.google.com/videoplay?docid=3834454834833982503]Prius e-CVT in action: A view of gas engine RPM at 65 MPH.[/ame]
    This is the video of how it feels to drive in EV mode:
    [ame=http://video.google.com/videoplay?docid=8064680594188841431]Sound, Feel and driving experience of a Prius[/ame]
    Another hybrid exclusive premium feature - Fun in traffic jam:
    [ame=http://video.google.com/videoplay?docid=5629875641973044508]I-495 LIE Traffic Congestion Utopia (70 MPG in Prius)[/ame]
    You can't do that with Diesel.
  16. Indyking
    1,280
    Thanks for all the replies, but my decision of buying a Prius over a TDI Jetta is weakening as I learned more about 2 cars. Here are the facts collected so far after extensive research, not just based on individual negative experiences of either Prius or Jetta TDI owners:
    1-Cost: A 09 Jetta TDI will cost at least 2k less than a similarly equipped Prius (III), because most VW dealers right now are offering 1.5K bellow MSRP and you get 1.3K of tax credit with the TDI until the end of 2010 (no tax credit for Prius anymore!)
    2-Fuel efficiency: They show similar MPG in the highway but the Prius is a clear winner in stop and go traffic. That’s what the Prius is all about, fuel efficiency.
    3-Performance: This is where the Jetta TDI crushes the competition. The high torque and power of the TDI diesel technology gives the Jetta a very pleasant, powerful, and much funnier drive experience. I have test drove both, there is no comparison here no matter what 2010 Prius owners say. The Prius performs like a scooter when compared to the Jetta TDI. No kidding.
    4-Maitainance: True cost of ownership is similar in both over a period of 5 years according to Edmunds but they do not take into consideration battery replacement in the Prius due at 250K at a cost of 2.5K. The Jetta TDI is a much better choice in a long run because new TDI diesel engines last for much longer time than gas engines. By the time you need to replace the battery in the Prius is also about time to replace the whole car because the small gas engine is probably in the end of its lifetime. No wonder 60% of European cars are running in TDI diesels, not hybrid gasoline-electric.
    5-Interior: The Prius is a winner here, it has a more refined interior with a high-tech feeling and more room than the Jetta TDI sedan, believe or not. The Jetta TDI wagon has a lot more room than the Prius though if you like that one.
    6-Exterior: The Jetta TDI does not have a particularly appealing look but certainly better than the Prius. This is fun, because every single Prius owner will say they like the exterior look of the car but they "forget" what their reaction was when they first saw a Prius, especially the back part... what ugly car is that? Remember now?
    7-Green: Here is what most people don't know. The Jetta TDI is a lot "greener" than the Prius since it has lower carbon emissions and the extraction of the minerals that make up the Prius battery is far from being a green initiative as the process greatly degrades the environment. The "green" tag of the Prius is just good marketing, something that VW of America should learn with Toyota.
    8-Fuel prices: Diesel is cheaper now and several specialists is forecasting this trend will continue for a long time. Diesel prices tend to be more expensive in the winter and cheaper in the summer (the opposite of gasoline), but it's in the summer when you drive the most, so one is likely to safe a lot more in the pump with diesel compared to gasoline in a long run.
    Bottom line: Unless most of your drive is stop and go traffic, it doesn't make much sense to pick a Prius over the TDI Jetta. The Jetta is a clear winner overall. Also, if you’re a car enthusiast, you will find driving the Jetta a lot more fun than the Prius. Just drive both and you will see what I’m talking about.
  17. Indyking
    1,280
    Forgot one more item from the post above:
    9-Reliability: There is a misconception that VWs cars are not reliable. Unfortunately, this was built in the US culture in the past and it stills sticks around even though the latest VW models are a lot more reliable than most people think. It’s a cultural problem! Go ask any European or South American person what brand is more reliable, Toyota or VW, and they will say VW with no hesitation. Typical new VWs have a specific characteristic of being fuel efficient but yet powerful with simple interior but yet very functional and solid. They are safer too. The Jetta TDI has higher safety scores than the Prius. The real problem with VW of America, unfortunately, is the bad reputation of the maintenance service in the dealer. Many VW dealers are indeed not well qualified, but there are many VW gurus spread all over the country that understands well how the beautifully engineered VWs work and will take good care of it keeping it running smooth at low cost.
  18. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    I've just read through the posts here, and I'm glad you've been inquiring about the 2010 by giving us info on intended use and how it would compare to the Jetta TDI. I'll respond to some of your specific points below, but I wanted to make a couple of general comments first.
    • I have not driven a 2009 Jetta TDI. In fact, I haven't driven a Jetta TDI. I have been in several TDIs in Europe and I found them surprisingly sprite.
    • I have owned a Gen2 Prius ('07) and a new Gen3 (2010). There is hardly any comparison in driving feel between the two (I have the Model V with 17" wheels, so that does make a difference), because the 2010 is a standout performer.
    • I feel from your responses that you just don't want to take to heart the comments received. I grant that the comments are coming from true-blue Prius lovers, but I don't see that you benefit from ignoring some of the comments.
    • Have you driven that route from Indiana to Wisconsin very often? If you are going to be driving the Borman Expressway (I-90/94) and the Tri-State Tollway (I-294), you'll not be driving 80mph that often! You'll be experiencing road work on a regular basis and traffic jams just when you don't want to see another car.
    • Remember: I haven't driven the Jetta TDI, and I AM a Prius lover.
    That is news to me. I didn't know the credit existed for the TDI. Please make certain you not only qualify, but that you'll be able to take advantage of the tax credit. Its applicability depends on how you file and your income.
    Similar MPG for Highway? The Prius is rated 17% higher than the Jetta TDI (manual) -- even higher (20% higher) compared to the automatics. And that is based on running the Prius in standard mode. At highway speed it makes sense to run in Eco mode, and the numbers will be higher. My recent jaunt showed that regular 65+ mph numbers were in the 54 to 56 MPG range -- and that is with the car brand new and running on 17" wheels.
    I'll have to take your word on this one, though I have my doubts given my recent experience with my new 2010 Prius V. Did you test drive the car you wanted (a 2010 Prius III, I believe)? Did you drive it in the various modes (Normal, Eco, Power)?
    I've got to question some of your reasoning here. Where do you find support that the VW TDI diesel will last "for much longer time than gas engines"? You are looking at a battery replacement at 250,000 miles and then saying it would be time to dump the Prius then, anyway. Do you really intend to drive any car 250,000 miles? If so, then look at real life costs expressed by people who have driven cars than long and far. I haven't done this, and I have only the PC postings to look at, but it sure seems that people have been driving the Prius for many, many miles at minimal maintenance cost.
    I didn't know 60% of European cars are running in TDI diesels, though I don't doubt it is a high number. They are running TDI diesels because of fuel costs and car costs -- and they want better performance than the very small gas engines. The downside is that European diesels are not nearly as clean as those sold in the U.S.
    I believe it. I have the 2010, and the fit and finish is excellent. Space is more than adequate. The hatch beats the pants off of any mid-size sedan in terms of usable space.
    OK. This is simply a matter of preference. (I have to say it that way, right? I can't stand the look of the Jetta, and I find the Gen2 Prius much more appealing than the Jetta. The 2010 Prius is downright sexy in comparison. Again, each to his or her own, though. If it comes down to looks, and looks are important to you, then go with what you like. Who wants to drive a car she considers ugly or unappealing?)
    And where did you get that information? The Jetta TDI does NOT have lower carbon emissions than the Prius. Take a look at both the Annual Petroleum Consumption and Carbon Footprint "scores" as reported at www.FuelEconomy.gov. This is information assembled and provided by the U.S. Dept of Energy and the U.S. Environmental Protection Agency. For Annual Petroleum Consumption, the Jetta TDI (manual) scores 11.6 barrels; that is nearly 70% higher than the Prius' 6.9 barrels. For Carbon Footprint, the Jetta TDI (manual) scores a 6.2 (annual tons of carbon dioxide emitted), and that is also nearly 70% higher than the Prius score of 3.7.
    The "extraction of minerals" issue has been addressed and debunked scores of times over. Please search not only this site but others. And rethink your uses of batteries of any sort before believing the Prius is the end of the world in terms of use of metals. Just look at the extra metal used in the production of the Jetta engine!
    Even with Diesel assumed to be 7% less expensive than gasoline, EPA predicts the Prius will cost 3% less in terms of fuel use. And that is based on driving 15,000 miles per year -- much less than your intended use. Even if you have a higher percentage of highway use than in EPA's model, the Jetta is no winner in fuel prices. I'd have to see the predictions you describe, because the trend for many years now has been just the opposite.
    I can't have a definitive say in terms of comparison without having driven the Jetta. At the same time, I just can't see how you come away with a "clear winner overall." If you want the Jetta more than the Prius, that is enough to make it the clear winner, and you don't need any other justification. The Prius is the "winner" in terms of fuel economy, space, comfort, resale/retained value, environmental impact and features. The Jetta is the "winner" in terms of initial cost, given the tax credit. I'll go with you in terms of Jetta being the winner in the "funner to drive" category -- even though I have severe reservations now that I'm driving the 2010 Prius. The points of "contention" would have to be looks and maintenance. Maintenance figures in to the overall cost and value of the car, and you need to consider how long you'll have this next car and how many miles it will be driven. Also, I recommend looking to reliability (Toyota is the clear winner there).
    If it comes down to looks and fun, you've made your decision and I'm certain you'll be very happy with the Jetta. If you want to base your decision on dollars and sense, I just don't see the Jetta as the winner, and I think you may be disappointed with the Jetta -- in those terms, that is.
    The Prius isn't for everyone (thankfully!!), but please don't toss it out because of a fiscal or environmental analysis that may be flawed.
    4 people like this.
  19. Indyking
    1,280
    Dear "a priori"
    I found it perplexing and allow me to say, ridiculous, that you are comparing the prius with the jetta tdi without never actually driven the latest. Sorry but you sound like the typical buy-prius-no-matter-what-others-have-to-say or perhaps I-cant-get-over-the-fact-I-bought-the-new-prius-without-checking-out-the-jetta-tdi. It's too late now! Later I will post here the sources where you can get the right info abot the Jetta, I see you have had the wrong information.
  20. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    With assertions like this ...
    ... you sound like you're part of the typical buy-anything-but-prius-no matter-what-others-have-to-say-and-regardless-of-how-truthful-it-might-be-and-while-we're-at-it-let's-troll-the-Prius-forums-a-bit-in-the-guise-of-asking-for-help-because-maybe-there's-a-newbie-just-gullible-enough-there-to-believe-it crowd.
    Sheesh! If you really were interested in the truth, you would have done some serious fact-checking on that one. But instead you've cost yourself substantial (all?) credibility.
    3 people like this.
