Hybrid Automotive Charge/Discharge
Discussion in 'Gen 3 Prius Main Forum' started by cww, Jan 5, 2020.
  1. cww
    cww Junior Member
    23
    2003 Prius
    Ok so this weekend I did a 2 cycle charge discharge on my 2011 Prius. I have only done this one other time but it seems like when on the second discharge it never goes down to 134 it will stop at 187 or something and make that noise and stay on idle. After a full balance it did charge up to 243 only 241 in the pic below I forgot to take a picture before I unhooked it. Has anyone else experienced this or know what it means?
  2. cww
    cww Junior Member
    23
    2003 Prius
    Sorry here is the picture.
    Grit likes this.
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Are you sure it didn't automatically stop at 134v and then float back up to 187v minutes later?
    Grit and Raytheeagle like this.
  4. cww
    cww Junior Member
    23
    2003 Prius
    I have the newest model, I wasn’t at home so I guess that is a possibility. In your experience how long does the discharge process take?
  5. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Every battery will differ, but it should finish at 134v in under 8 hrs.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    If it was discharging and you found it in idle, I’d say it made 134 volts;).
    Once you get below 190 volts, the discharging cycle is much faster. If you’re not out there when it happens, it bounces back quickly:cool:.
    Good luck with your reconditioning and keep us posted .
    Grit likes this.
