Hybrid batteries surpass all expectations
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by usbseawolf2000, Feb 21, 2009.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    When Toyota's Prius first hit Japanese showrooms in 1997, I was highly skeptical that hybrids would catch on. Not only was the technology really expensive, I thought the nickel-metal hydride batteries would prove to be the Achilles Heel in the system. Sooner or later you'd be facing an expensive replacement bill, right?
    Well, here we are more than a decade later and those batteries are proving to be amazingly reliable. Toyota now has sold over 520,000 hybrids in just the American market. Honda has sold over 300,000 worldwide. Ford is just about to break through the 100,000 mark. The only reason they could sell so many hybrids is that the technology is working exactly like it's supposed to, including the batteries.
    The key to their longevity is that these batteries do no go through deep discharges. They still retain something like 40% charge when the engine comes on to re-charge them. But it may be possible to push that envelope. Though Ford isn't talking, some believe it got such jaw-dropping fuel economy numbers with the new Fusion hybrid by pushing the battery into deeper discharges.
    Toyota did tell me that for out-of-warranty customers the failure rate is only 1 out of 35,000. That's a pretty impressive number, but it also translates into a parts-per-million failure rate of 28. I know Toyota pushes its suppliers to hit a PPM rate of 10 or less, so as good as it is, I'm sure Toyota is pushing for better durability.
    Toyota sells all its returned batteries at very low cost to Kinsbursky Brothers, a huge recycling company in Anaheim, California. In fact, Toyota started recycling batteries with them in 1998 when it sold the EV RAV-4 in California.
    The nickel-metal hydride battery is about to be challenged by lithium-ion. There are plenty of questions about the durability, reliability and cost of these new batteries. Perhaps they will prove to be as good as the nickel-metal ones. But right now they're much more expensive, and it takes more energy to recycle lithium than it does to get virgin lithium. As a result, there is no market for post-consumer lithium. That's why some automakers, notably Toyota, believe that nickel-metal batteries will be around for a long time to come.
    Source: Autoline on Autoblog with John McElroy - Autoblog
    I only picked the paragraphs that I found interesting. Follow the link to read the entire article.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Keep in mind that some folks still believe that Toyota is single handedly responsible for the "moonscape" around Sudbury
    Hint to trolls: there *is* no moonscape around Sudbury. That was cleaned up in the 1980's, long before the Prius came along.
    Toyota purchases a teeny fraction of total smelter output, the rest goes to the US car industry and steel industry
    Another hint to trolls: Google is your friend. Look it up. RTFM, etc
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I bet that if you take out the failure rate of the Classic the 2G is approaching that 10/million failure rate that Toyota likes. I'd sure love to see some official numbers.
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    An auto journalist providing accurate details and knowledgeable commentary...what a rarity. That was good reading devoid of random opinion.
  5. timwalsh300
    timwalsh300 Member
    131
    16
    I thought people in the Prius community have already experimented with this (adding more battery capacity) and found no impact on fuel economy. :confused:
    Personally, I can only think of a handful of situations when I've maxed out the battery and could have used more capacity for regeneration. Only on some really big hills...
    Tim
  6. efusco
    19,891
    1,194
    Nixa, MO
    Those who have added extra capacity generally enjoy an approximately 10% improvement in FE depending upon conditions. More capacity adds flexibilty to the charge/D/C cycles.
  7. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Based on this, Why is Rick Wagoner still CEO of GM ?
  8. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Because the GM Board of Directors has not changed.
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    What the hell, plenty more taxpayer money for them to keep going SOP
  10. efusco
    19,891
    1,194
    Nixa, MO
    The thing that keeps nagging me is the title... "exceeds all expectations" I don't think that's true at all. It isn't exceeding my expectations...or Toyota's...or most people who took the time to learn and understand how these things work.
    It did exceed the expectations of the ill informed (intentionally or otherwise) and misled (by the press and other critics). And somehow they're surprised by that. Curious.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, trying to convince barely literate hillbillies that a Prius battery actually does last more than 2 years, or costs less than $15 G's, or does NOT contribute to the "moonscape" around Sudbury, Ontario .... perhaps that has exceeded expectations
  12. Patrick Wong
    18,200
    6,493
    How would Toyota know? If the vehicle is out of warranty then a salvage part may be installed or the vehicle may be scrapped. In either case this would not be apparent to Toyota. Toyota would only have visibility to owners who elected to pay $4K to a Toyota dealer to have a replacement installed.
    How about in-warranty failure rates? I've owned three Toyota hybrids and had in-warranty traction battery failures on two (2001 Prius, 2006 HiHy.) I understand that Classic salvage traction battery prices are currently near $1K (if batteries can be found) which implies that battery failure rates equal or exceed scrap rates due to major accidents.
    I would agree that 2G traction battery failure rates appear to be exceedingly low, since we've seen very few reports about this on the various Prius forums. Further, the price of 2G salvage batteries is quite low, around $400 or so on eBay (plus shipping), which is more evidence that there's little current demand.
    http://cgi.ebay.com/ebaymotors/04-07-Prius-Hybrid-Battery-Pack-G928047100-OE-LKQ_W0QQitemZ220362526626QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item220362526626&_trksid=p4506.c0.m245&_trkparms=72%3A543%7C65%3A12%7C39%3A1%7C240%3A1318
  13. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    The current Prius is the best engineered car in the world. It has stood the test of time. The next generation car will have a break-in period of a few years to iron out the inevitable flaws. That's why the current generation car is a wise choice.
