Hybrid batteries vs Hybrid ECU?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Richiemoe, Jul 30, 2019.
  1. Richiemoe
    Richiemoe Junior Member
    67
    West Michigan
    I've learned a LOT from this forum, thank you!
    Now, i need to learn another thing... LOL
    How can you tell when the ECU is going bad, and not the battery cells?
    I should have replaced the whole pack when this first happened, but i replaced a single cell instead, and have been since then... Maybe 6-7 cells replaced in the last few years. I replaced another bad cell over the weekend, and cleaned the fan, it was DIRTY! Blew out the rubber lines, and wipe the black plastic tubing. I put it back together and all seemed to do well. Until i went out to the car at lunch today, to make some phone calls. I had the side doors open, but it got HOT with no wind the and the sun on my. So i turned on the car/AC. All was well. Then the dash lit up after 10 min, again with the red triangle, check engine light and (!). So i used the bluetooth scanner with the torque app and it showed P0A80 again. No back cells. The batter temps were about 102° (fan lvl 2), so i assume that is why the code came up? I'll scan it with my laptop when i get home from work, but i suspect it might show P3000, without indicating any bad cells, just those two codes... Over the weekend before i changed the bad cell, it threw P3000, P0A80, P3017, P3018 (after testing the two cells are fine), B1411 & B1421 (pertain to the AC, but it works fine and been on forever), and this one i think is new, C2318 "Low voltage error (power supply malfuntion) under the transmission tab in techstream. But i think C2318 might have to do with the other codes and bad cell (14.3v).
    On Friday, i called the dealership (while still in traffic) and they said that they had no way of being able to tell if it is for sure the ECU or not... Just as i got stuck in traffic and the bad cell kept throwing a code, not matter how many times i cleared the codes. Then, i was stuck in traffic. It got so bad that i could feel something disengage and it no longer charged the HV batteries. I couldn't accelerate over 16mph! I was stuck going up a small hill, and traffic was passing me. Once i got momentum, they stopped again. Once i got to my destination, i turned off the car, waited a few minutes and turned it back on again. It started charging the HV batteries again, thank goodness!! So i was able to get most of the way home without the code showing again, and definitely no acceleration issues.
    The car is a 2006 Prius with over 220k miles, i'd like to get past this Michigan summer and at least until spring, before i replace it. I think the cool weather will help, a lot. I just use it for work, not long trips across the state anymore, not reliable... This previous fall/winter, it would rev really high once all of the charge bars were green. It seemed to shift a little funny, but i think that was because of the cold. I started driving it last fall when my wife started driving our new 2012 ford flex. My wife did say it started shifting a little weird when she accelerated fast, that after i changed the transmission fluid. I drive it like an old man and haven't noticed that... lol Sometimes it shifts a little hard when going slow and switching between battery/gas. Not horrible, but noticeable... Not sure why????? Slightly low on fluid? Hard to check these things...
    Summary: Is the ECU bad? Just replace the whole HV pack? Could the transaxle be going, too? Deal with the heat and keep clearing the codes, and see if it keeps happening this fall?
  2. bobodaclown
    bobodaclown Member
    214
    71
    What's the status of the electric pump for the inverter? Had it ever been replaced? Is the coolant moving?
    Richiemoe likes this.
  3. Richiemoe
    67
    West Michigan
    I don't know... I replaced the engine/belt driven water pump, i think last year. I'm not sure about the inverter... I feel dumb asking, but how can i tell if coolant is moving? I just googled "prius electric pump inverter" and it looks like it mounts to the inverter. I've never touched it and actually just learned the name of that unit, just now.... LOL I did replace the spark plugs slightly over a month ago, doubt that has anything to do with anything, but i've seen other threads ask about them being replaced for some reason....
    Edit: I just read more about the inverter pump. I didn't know that it as linked to the transaxle fluid, i thought it was separate, just for the inverter. I bled it properly, but maybe it is a little low or some air bubbles left in it still? When i changed the transaxle/transmission fluid, i put the car on four jacks to get it off the ground and to make sure it was level. Just as fluid was coming out the fill hole, i capped it. Is there a way to check the fluid level, besides jacking it up, making sure it is level, then opening that bolt/cap?
    #3 Richiemoe, Jul 30, 2019
  4. ChapmanF
    15,435
    Both fluids are pink(ish), but they are not the same. The transaxle has transaxle fluid in parts of it, and inverter coolant flowing through others. Mixing them up leads to suffering.
    jerrymildred and Richiemoe like this.
  5. strawbrad
    953
    999
    Your battery is the cause of all these problems. The only thing that sometimes goes wrong with the battery ECU is corrosion can build up in the orange plug that holds the voltage sensing lines. A simple visual inspection can check this.
    Your post sounds like you have been playing wack a mole with this pack for quite awhile and now it's all goofed up. Did you replace just one module despite having codes for two blocks being bad? Are you doing any testing or reconditioning of the modules?
    Learn how to do a forced charge and discharge while monitoring the battery with Techstream or Hybrid Assistant. That will give you a much better understanding of the condition of your battery.
    Richiemoe and Raytheeagle like this.
  6. Richiemoe
    67
    West Michigan
    Thank you VERY much for your response! Yes, definitely been playing whack-a-mole... While i've learned to test the batteries using my multi-tester and a vehicle headlight, i still feel like i'm missing something. From all of the posts that i've read, it feels like information overload and a bit overwhelming...
    1. No corrosion. All is good. I took my time putting the battery pack back in and visually inspecting everything. I took a pic of the techstream screen, everything looked normal last night, minus the cell temps.
    2. On some battery packs, if one was obviously low at 12v or 14v, i had only replaced one. But recently, i couldn't tell which was bad in the group, so i replaced both, the last few times. The last time, i only replaced one. It usually worked for 6 months, before another dash light came on with a cell group that went bad. This summer, all the time now.....
    3. i have tech stream and torque pro. i use torque to clear the codes, when i assume it is just hot cells... then use tech stream when i get home to see if any cells went bad.
    Last night, i scanned again, these are the pics. These are the only two codes that came up. In the active test, i only see the battery pack temperatures as high, everything else looked normal. Am i missing something? 20190731_175332.jpg 20190731_175452.jpg 20190731_175640.jpg 20190731_175646.jpg 20190731_175701.jpg
  7. Richiemoe
    67
    West Michigan
    Thanks, i was confused from the posts that i read. Each have separate coolants, but the inverter pump circulates both? I've replaced a jeep transmission, but this transaxle, i don't fully understand yet...
    I checked the oil and inverter coolant levels before i left work yesterday. They showed showed normal. Also, there were "waves" in the inverter coolant reservoir. All appears normal.
  8. ChapmanF
    15,435
    Well, be careful here to make sure you're not mixing up two completely different kinds of things, in three or four separate systems.
    The engine has coolant. It is a pink/red, watery solution of ethylene glycol. It gets pumped through the engine to cool it. The engine also has oil. It is, well, oil, and it's usually sort of amber in color, and it is pumped through the engine to lubricate it. The engine coolant does not mix with the engine oil, and you don't put one where the other goes. If they do mix, you replace the engine.
    The transaxle also has oil. The oil in the transaxle is reddish in color, it's called ATF-WS, and it is pumped through the transaxle to lubricate it. And the transaxle also has coolant. The coolant is exactly the same pink/red watery ethylene glycol solution that is used to cool the engine, but the plumbing is separate.
    Because, in the transaxle, the coolant and the oil are the same color, they are easier to mix up, but they still don't mix, and you don't put one where the other goes, or you can replace the transaxle. Even with the color similarity, they are easy to tell apart. The coolant is pinkish and watery, the oil is pinkish and oily, and they smell different.
    The transaxle oil stays inside the transaxle and gets pumped around. The transaxle coolant gets pumped through the transaxle (in completely different passages, never mixing with the oil), and through a little radiator in front of the car, and through the inverter to cool it also, and back through the transaxle.
    One pump circulates that coolant through the transaxle and inverter (and is usually called the inverter pump, for short).
    It's separate from the pumps that circulate the engine coolant through the engine (and there are three of those in a Gen 2, one that runs when the engine runs, one that runs when the engine doesn't (if you're using the heater), and one used for preheating when the engine is started.
    #8 ChapmanF, Aug 1, 2019
    Richiemoe, SFO and jerrymildred like this.
  9. strawbrad
    953
    999
    Yes.
    The screen shot shows your battery under discharge which tells much more than just sitting idle. (Batt Pack Current Value is 4.82 Amps.) The odd values that stand out are the Delta State Of Charge at 38%. It should be zero and none of the other data supports such a large D SOC. The internal resistance values are all really high. They should be around .024 ohms. The voltage spread of the modules looks good.
    Run a forced charge, car running in drive, brake and gas on hard, the car will just sit still and charge the battery. Record the screen shot.
    To run a proper discharge test car on and engine warmed up and off. Turn on the AC, high beams, rear defrost, and car in reverse. Give it just enough gas to keep the engine off. Record the data.
    Run each test for a couple of minutes.
  10. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    Have you checked the battery pack cooling fan is working? And clean?
  11. Richiemoe
    67
    West Michigan
    Thank you very much for you very in depth explanation! I change the oil myself, using Napa Full Synthetic and a Platinum filter. I replaced the water pump about a year ago, maybe less. And just over a year ago, i replaced the transaxle fluid, using the expensive proper stuff and watching a good youtube video. I have not replace the inverter pump, but i still see waves in the inverter coolant reservoir. But i did not understand how everything worked within the system.... Good to know though, thanks again!!!
    The screenshots were from when i was driving, should i test it again while stopped? I was going about 55-65mph...... By doing this test, will it balance the batteries? Or better show what cells are bad? Both? When i put the car in reverse, how far do i need to drive? Or keep my foot on the brake? Thank you for your in depth response!
    When i most recently replaced a cell, i very thoroughly cleaned the fan, which was really dirty. Then cleaned the black plastic tubing, and blew air through the rubber hose the connects to the top of the batteries.
  12. strawbrad
    953
    999
    The forced charge and discharge test will not balance the battery. It will show which blocks have the weak cells. The test is run with the car sitting still. Run each test for at least two minutes. Capture a screen shot while the battery is under load and charge. The weak cells will have the highest voltage on charge and the lowest on discharge.
  13. Richiemoe
    67
    West Michigan
    Thank you for your quick response! What if none of the cells are "bad"? Is there another possible reason why the batteries are running hot, other than it is really hot out, and they are getting older?
  14. strawbrad
    953
    999
    Take ten minutes to run the test and post the results. It will show the weak cells.
    Skibob likes this.
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    Also, did you use an inch pound torque wrench to properly tighten the 8mm nuts in the module posts?
    Or did you just kinda guess?
    Improperly tightening things can cause a world of problems.
    Skibob and Richiemoe like this.
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,889
    Columbia, SC
    There is no indication or mention that you checked the freeze frame data provided with the P0A80. If you haven't, you really need to. Click on the snowflake icon to the left of the code and it will provide a screen full of info that was captured at the instant of the code. It can clear up a lot of guess work...................
    Please post a screen capture of the freeze frame data. Then we can really get you going in the right direction...
    Skibob, Richiemoe and strawbrad like this.
  17. Richiemoe
    67
    West Michigan
    Makes sense, thank you! I'll try to test it tonight.
    Last night, i drove more than just to/from work, which usually signals a dash light, as the last little bit of driving is in town, so i uses the batteries more... Plus the cells have been heating up. But it did show P3014 (Battery Block 4 Becomes Weak). So i'll have to take it apart again this weekend.
    I did not use a torque wrench, just kinda guessed. They aren't loose, but i'm not breaking the treading off, again........
    I did not know what the snowflake was for, thank you! I'll post those for sure, hopefully tomorrow! Working on this almost every or ever other weekend is getting old. Definitely wish i did it the correct way, the first time, and learned the correct way of doing this, since then. I had gotten lucky, because it would last usually 6-8 months, before another cell would go bad. Now it is all the time.....
  18. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
  19. Richiemoe
    67
    West Michigan
    And it is MUCH appreciated!!! As my wife and I work through the Dave Ramsey plan, we have everything paid off but the house and a 2012 Ford Flex. Once the flex is paid off, i can start saving for another car, probably a newer prius. But with my second child on the way(JUST found out) and still have an entire floor to finish in our project house (looked easy after watching HGTV), the more time i can work on the house and less playing whack-a-mole with prius batteries, the happier my wife will be!! LOL Thank you all for your input!!!
    I'm decent with maintenance and before the ford flex, all vehicles were around 220k miles, or more! The '95 wrangler only at 156k. lol But with any other project, i find the issue, replace it, and back on the road. I'm having trouble wrapping my head around what all is involved with the prius, as it takes a little more know how. I'm very thankful for all of the input! I played hookey and took the jeep to the sand dunes yesterday, so i'll for sure test the prius tonight/weekend. :)
  20. Richiemoe
    67
    West Michigan
    These 4 images are from the charge mode, just over 2 minutes and full green bars. HV control and hybrid battery tabs. I was rushing and accidentally unhooked the 12v battery, while taking stuff out. Amd remembered i needed to do this test still. But it reset the codes. So these codes are before the code came back on. But since it is the charge test, safe to assume it is ok? 20190817_192435.jpg 20190817_192424.jpg 20190817_192250.jpg 20190817_192228.jpg
