Hybrid Battery almost always fully charged on a long trip
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tony Rico, Mar 25, 2013.
  1. Tony Rico
    Tony Rico Junior Member
    2008 Prius gen ll
    I had to take an unplanned out of state trip this week. For most of the highway time (2 days each way at +/- 65mph) the hybrid battery was almost always fully charged(green bars). The arrow every few seconds pointed towards the battery indicating charging even though the battery showed all green bars. Every now and then, several times per minute it would out pulse a short blast of energy to the system but not enough to bring it down to blue bars. MPG was down about 10% . P>G didn't seem to help except when I was in town. Taking my foot off the gas pedal didn't always result in the 99.9 indication unless I was going down an incline. I went from Northern Michigan to South Louisiana so temperature wasn't the culprit
    The only thing different is that my 12v ignition battery failed just before leaving and the dealership replaced it.
    At normal speeds, when I pulled off the interstate for gas/food/sleep the system worked OK, blue bars charging and discharging and good gas mileage. P&G worked normally.
    I've had this car for 5 years now and only a few times over that period have I noticed the hybrid battery fully green.
    I hope this was enough if not too much information.
    Any ideas?
  2. uart
    uart Senior Member
    4,215
    1,201
    Australia
    When you say "fully green" that should mean all eight green bars, however I strongly suspect that you're actually talking about 7 green bars - which is just a shade above the nominal level.
    If you think it's operating strangely though, I'd try pulling the 12V positive lead from the battery and leaving it off for 15 to 30 minutes before reconnecting it to reboot all the ECU's. Occasionally people report anomalies after incidents with the 12V system.
    koolingit likes this.
  3. epoch_time
    epoch_time Active Member
    234
    108
    las vegas
    I would also suggest disconnecting 12 battery for 15-30 minutes to reset ecu's.
    I would disconnect 12 battery by unplugging the two wires from positive battery connection..
    Remove red plastic cover from positive battery clamp to expose the plug in connections..
    The small size wire (voltage remote sense lead) should be unplugged first.
    The large size wire ( the high current connection ) should be unplugged second..
    Leave disconnected for awhile as systems can retain voltage for hours...
    15-30 probably sufficent to reset ecu's longer if possible..
    You will loose radio memory presets, a & b trip milage.. drivers up windows setting (just hold window up botton all the way for 1
    second past fully up after everything is reconnected ).
    If you have disabled reverse gear beep or seat belt beep they will be reset back to beeping (factory settings).
    To reconnect 12 battery, connect large wire plugin first then small wire plugin secondly..
    Replace red snapin cover on battery cable/clamp..
    Just in case your not sure where battery is located it is passenger side rear of car.
    your will have to lift out plastic storage compartment above spare tire to get to battery.
    You could disconnect 12 battery by removing negitive cable clamp connecton..but the problem i have with this is when reconnecting it.
    Could result in the system being powered up and down several times while wiggling connector back on battery post/terminal..
    Using the plugin connections results in a cleaner restart of ecu's/computers..
  4. Jeeperslimited
    Jeeperslimited New Member
    Chouteau, Oklahoma
    I am having the same problem, battery alway staying completely charged. Took my 2007 Prius II into the dealership for body work and it started acting this way. It almost never stops charging the battery. Even at times, say when I am going up a hill and need the battery power to help it still charges. I have lost to about 10 MPG. I too had about two months prior to taking it in for body work changed out the 12v battery. Has anyone else had this issue?
  5. bisco
    49,732
    welcome to priuschat! try disconnecting the 12v battery for a minute. if that doesn't work, tell them what happened at the dealership and let them look into it.
  6. Cory Potrafka
    Cory Potrafka Junior Member
    51
    Floyd, VA
    Having a similar issue except mine occurred suddenly and with a carnival of dash lights to accompany it. Red triangle, check engine, amber circle encased in parentheses containing an exclamation point (brakes or tire pressure maybe?), and on the screen the word "problem" when i start it that then turns into a red car with an exclamation point in the upper left hand corner. After all these lit up the battery gauge went from one red bar to full green bars in less than a mile. has been full green bars ever since, always indicating that it is continuously being charged, even tho completely full, and never using power back from it. Any ideas? Also hybrid battery fan runs full speed full time. It was never even audible from the driver's seat in the past.
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Cory, the codes behind the idiot lights need to be read. Read the voltage of the 12v battery with a volt meter or through the MFD. We'll be able to offer better advice after seeing the codes & the voltage of 12v.
  8. Cory Potrafka
    51
    Floyd, VA
    12v battery readings look ok. Waiting for my Mini VCI to arrive. Should be here by Monday or sooner, I'll post codes here. Thanks.
  9. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    I noticed somewhere the HSD likes to be charged between 40% - 80% to protect the battery pack. In my two months of driving a 2007 Prius, it got to 40% once per ScanGauge (purple bars), and once all eight bars and read 86% SoC. :eek:
    Not the foremost expert, but my inclination on an eight bar read out is to adjust pedal pressure to run the SoC down.
