Hybrid Battery Block Numbering ??? Left to Right
Discussion in 'Gen 3 Prius Technical Discussion' started by HV Battery, Sep 10, 2018.
  1. HV Battery
    HV Battery New Member
    22
    Oklahoma
    so what way are the hybrid cells or blocks number, from Left to Right or from right to left ??
    and from which way looking at the HV Battery...
  2. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    It depends on the car. The Gen 2 are from the right(as installed in car) to left side. The Gen 3 are reverse(left to right).
    HV Battery likes this.
  3. PriusCamper
    PriusCamper Senior Member
    11,055
    4,499
    Pacific Northwest, USA
    So you're basically saying that module #1 is always furthest away from the Battery ECU, wires, sensors, etc.?
    I've seen many post about this question and I always get confused.
    It'd make more sense if module #1 is closest to ECU, etc., But I'm beginning to think what your saying is the right way... Can anyone else in here agree or disagree?
    tangerino likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,890
    Columbia, SC
    I am familiar with only Gen 1 and 2.
    Gen 1..Block 1 is closest to the ecu end of the battery
    Gen 2...Block 1 is furthest from the ecu end of the battery.
    I merely disassemble Gen 3 and Gen 4s for parts so I haven't really paid attention to order of blocks in them.
    The info below was posted by @Hybrid Battery Exchange a while back:
    Battery blocks are counted from the module which you attach the negative lead, voltage grows with each block. Voltage at block 1 will be ~16 volts, voltage at block 14 will be ~224 volts.
    Gen 2 and gen 3 are the opposite. Gen 2 uses a long negative lead and a short positive lead, gen 3 uses a short negative lead and a long positive lead.
    If you're working on a Camry or Lexus battery and are confused which block is which just follow the negative lead to block 1.
    Mendel Leisk and PriusCamper like this.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    HV battery,
    What year Prius battery are you working on?
    Kswiss95 likes this.
  6. HV Battery
    22
    Oklahoma
    I think this is the answer i'm finding also, the 2nd gen is right to left & the 3rd gen is left to right. ....that's crazy
    AgNoir likes this.
  7. ericbecky
    4,369
    3,217
    Madison, Wisconsin
    Left and right are relative. Especially once the battery is removed from the car.
    Also depends which side you are looking at the battery from.
  8. Al Bundy
    Al Bundy Member
    140
    69
    florida
    great now I have a headache and still dont know what year car he's working on.. good luck Im going to bed.
    PriusCamper likes this.
  9. HV Battery
    22
    Oklahoma
  10. HV Battery
    22
    Oklahoma
    This is the only video I can find on reconditioning a Prius battery, and the guy says the cells are numbered from right to left
    But on all the forums I see it's labeled left to right. So which is it?
  11. TMR-JWAP
    6,193
    5,890
    Columbia, SC
    Holy moly.......................
    You have a Gen 2.....
    Module 1 is the furthest from the ecu.
    Module 28 is closest to the ecu
    Block 1 is modules 1 and 2
    Block 14 is modules 27 and 28
    Forget left and right, that is a BS way of looking at it because it is all relative to which side you're looking from.
    From post #4..................
    There are several different styles of batteries from different Toyota models and years. Using the above info will keep you straight regardless of what battery you're working on. Every module has a (+) or (-) molded into the plastic near each terminal. There are 2 cables which put power (+ and -) to the main relays. Based on HBE's information, wherever the main cable attaches to the (-) is module #1. On a Gen 2, (your 2007), this happens to be at the module furthest from the ECU.
    #11 TMR-JWAP, Sep 12, 2018
  12. ericbecky
    4,369
    3,217
    Madison, Wisconsin
    HV Battery
    Al Bundy likes this.
  13. TMR-JWAP
    6,193
    5,890
    Columbia, SC
    Post #9......2007
  14. PriusCamper
    11,055
    4,499
    I like this reply the best because it explains the logic for the numbering system... DC voltage travels in a specific direction and the way that voltage travels is the basis upon which the numbering is based...
    Till Hoffmann and tallman like this.
  15. Nick007b
    Nick007b New Member
    Trinidad & Tobago
    2014 Aqua
    Can you show me in this photo please? its from a prius C/ Aqua
  16. PriusCamper
    11,055
    4,499
    It's a DC high voltage pack, which means the current flows in the same direction always, which is negative to positive... Some say Toyota has broken this rule on some packs, but near as I can tell, where the negative high voltage cable first attaches to the pack is module #1 and the last module, in this case module #20 is where the high voltage cable first comes out of the pack.
    But more important, you need to make a spread sheet of all modules and get as much data on all of them, especially via load testing, so you can find bad modules before they go bad... It's a fool's errand to go after only the bad block that the car's dash lights find without also going after the bad modules that the dash light has yet to find...
    Skibob and Dxta like this.
  17. ericbecky
    4,369
    3,217
    Madison, Wisconsin
    Nick007b,P
    Step 1:Identify where the negative lead is.
  18. Rodger C.
    Rodger C. New Member
    Lancaster
    So I recently did a swap of battery modules from my Gen3 to my Gen2. It is telling me block 2 and block 3 are becomes low. How come?
  19. George W
    George W Senior Member
    911
    511
    San Antonio
    Gen 2 is Right to Left (mounted in the car).
    GG707 and Rodger C. like this.
  20. ericbecky
    4,369
    3,217
    Madison, Wisconsin
    Possible installation error?
    Here are some places to start your hunt for the problem....
    - check the polarity of the modules. They should be alternating every other module. Make sure you started with negative lead with a negative post of the module
    - check the torque spec of each nut on the module's terminal posts. You didn't just "guess" on tightness did you? You used a proper inch-pound torque wrnech when tightening them, right? 48 inch pounds.Randomly deciding that it feels"kinda tight enough" is not a good way to do things on a high voltage battery.
    - check that none of the terminal posts threads are stripped.
    - check that the voltage sensing wires and wire terminals are not crack or broken.
    - check the pins of the battery computer. make sure they are not corroded or damaged.
    chronon likes this.
