hybrid battery cell rotation
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nancytheprius, Oct 11, 2021.
  1. nancytheprius
    nancytheprius Active Member
    354
    152
    iowa
    I have an idea and please let me know if it’s a waste of time/efforts. My hybrid battery is still original and my 06 prius has 83k miles. it still gets great mpg and holds a charge as expected. I am thinking to swap the cells to put the middles on the outside and the outside cells on the inside. Would that extend the life a bit or just be a waste? I could also check for corrosion and clean that up at the same time if so. Any input is appreciated
    Thanks
  2. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    Personally, I think that won't really accomplish too much. You'd be better off leaving the battery undisturbed and expend your energy just doing some grid charging. But given your battery is now 15 years old, you probably should have started that 2-3 years ago. That would have given a better cost/benefit ratio between buying the equipment and extending the battery life.
    Are you experiencing any hybrid battery problems at the moment?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    No, not worth the trouble.
    A cleaning and inspection can be done MUCH easier.
    But that probably isn't necessary either.
  4. nancytheprius
    354
    152
    iowa
    Sounds good and no i’m not experiencing any troubles. Just have no idea how long it will still last
  5. bisco
    49,437
    sounds like the old, 'rotate your tires or not?' debate. on the face of it, it would seem to make sense, heat wise. but idk the details.
    have you reviewed the module voltages on dr. prius?
    #5 bisco, Oct 12, 2021
  6. Mendel Leisk
    38,707
    I'm with @bisco, especially if you've got it out anyways, cleaning the connections. Number them FIRST.
  7. nancytheprius
    354
    152
    iowa
    My obd2 scanner isn’t compatible with dr prius but i still monitor the voltages with a different app. When driving steady the max difference between highest and lowest is 0.2 or 0.3 V but when i floor it or demand a lot more power it’ll go up to 0.4 and i’ve even seen a 0.5 V difference
  8. bisco
    49,437
    i would be more concerned with resting voltages after the car sits a few days
    nancytheprius likes this.
  9. nancytheprius
    354
    152
    iowa
    Okay, I drive just about every single day and put between 200-300 miles a week, but I think this week i’ll have two days in a row of no driving. I assume once i park the last time before the two days off note all the voltages, and then right when i get back in after the two day gap look again to compare the differences? Is that what you would do? appreciate your help
  10. bisco
    49,437
    from what i've read, old cells deplete after sitting. if they sit too long, the computer can throw a code because they go out of balance.
    what you want is the low cell readings after sitting. that will tell you if the weak cells (if any) are in the middle (hot) or random.
    i'm no expert, just a thought.
  11. nancytheprius
    354
    152
    iowa
    i like the thought. i’ll update later if i find anything out
  12. nancytheprius
    354
    152
    iowa
    here’s the results after sitting for 3 days straight. i plugged in my obd 2 sensor right before powering off the car to get the first voltages and then plugged in right when powering on three days later (without pressing on brake) to get the second set. IMG_2805.jpg
