Hybrid battery concerns
Discussion in 'Gen 3 Prius Technical Discussion' started by JiffySmiffy, Aug 20, 2017.
  1. JiffySmiffy
    JiffySmiffy New Member
    Sherman, TX
    Newbie here, so pardon my lack of knowledge for post preferences... I'm noticing my hybrid battery drains very quickly with the AC on, and from what I read alot of you say that's normal. Its the heat of summer in Texas and I've heard the battery itself needs to stay cool or I'd just go without the AC (I work in the heat so it really doesn't bother me). I've been taking the long route to work just to avoid high-traffic areas. I can't even make it through a fast-food drive-thru without the charge dropping to one or two bars... So I'm planning a trip to San Antonio in October which means I'll have to drive through Dallas, Austin, AND San Antonio which almost guarantees some traffic along the way. I guess what I'm wondering is what happens if the charge runs out? I've heard talk about an "ICE" that monitors this but don't see anything in my manual about it. My 2012 Prius (just over 100,000 miles) has an engine brake option, which I've used in traffic before while killing the AC and radio and it seemed to help. It has an EV, Eco, and Power mode (which it says is for mountainous regions). Should I be selecting the Power mode in this instance? Would that save the battery from draining? Or should I just not worry about it when it gets down to one bar and have faith that it will re-charge on it's own? Any input will be appreciated.
    49,397
    welcome!
    ICE = internal combustion engine
    computer monitors battery. when you see 2 bars, it's actually 25% full, and the ICE comes on to give it a little charge. when you see full bars, it's only 85% full. these parameters extend battery life.
    make sure the battery intake grille is clean and uncovered. clean the fan, if you haven't, keep the a/c on high (use power mode for full a/c) and use window shades when parked in the sun. nothing else matters.
    don't worry, be happy.
    all the best!(y)
    Tande, Raytheeagle and JiffySmiffy like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    In our 2010 Prius II with 161 k miles I began to notice the HV battery draining frequently in traffic and cycling between full and empty faster than I remembered.
    I ended up purchasing the Prolong equipment and had @jeff652 install the harness;).
    I have done one top end balance and one 2 cycle reconditioning. The battery has better charge when in traffic and the mpg for our 2010 is 51.5:).
    If passing through Dallas, you could always pm Matt at @Texas Hybrid Batteries with any concerns.
    Hope that helps(y).
    JiffySmiffy likes this.
  4. jeff652
    jeff652 Senior Member
    606
    623
    Idaho
    It may be normal, or it could be symptoms of an aging battery Here is what you should watch for to assess battery health:
    ProlongĀ® Battery Systems FAQ – Hybrid Automotive
    Raytheeagle likes this.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Hey Welcome to Priuschat. Just enjoy your Prius I doubt anything is wrong with it. I have a 2012 with 145k on it and it's fine. Everything you describe is typical. We're in Fl. and use the A/C all the time. It does drain the hybrid battery pretty fast so don't worry about it. Just watch when your driving to see that the hybrid battery indicator doesn't go up and down real fast or erratically. Don't use B when your driving, just drive it and let the car figure out what to do. It won't let you drain the hybrid battery to nothing so don't worry about that. Here in Fl. I gets real hot too so just make sure the vent in the back seat to the battery is clear. If you have a dog make sure it doesn't get clogged with dog hair. Also make sure to keep the oil at the full mark. It only holds 4 qts. Not much when it's hot. I always add a half a quart when it gets to the half a qt. low. So just drive it, the car figures out what to do.
  6. Grit
    Grit Senior Member
    6,141
    4,055
    Wilkes Land
    Today was a miserable 109 degrees, I had the AC on half way blast commuting 6 miles back home from work. Typically I get 63mpgs back home even starting w/2 bars. But with 6 bars to start the home commute, today I got 38.1mpg. 1st mile back is all highway, last 5 miles was all idle in slow arse stand still traffic. Idling with 2 bars in slow traffic for 10 minutes (or drive thru) with AC will always mess FE up and drain the hell out of your traction battery.
