Hybrid battery dead on 76,000-mile 2006 Prius -- replace or not?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kent77, Apr 8, 2017.
  1. Kent77
    Kent77 Junior Member
    Philadelphia, PA
    I'm trying to figure out whether it's worth replacing my hybrid battery or junking my car and replacing it with something newer. Here's my situation:
    • I'm the second owner of a 2006 Prius (I purchased in late 2011 when it had 49,000 on the clock) and I have kept up maintenance on it pretty well;
    • It now has only 76,000 on the clock (so in retrospect I may not really be the target audience for a hybrid!);
    • The original 12V battery was replaced earlier this year (it died after I left the car unused for about a month in the winter);
    • My mileage took a hit immediately after -- whether somehow to do with the replaced 12V battery or to do with the effect of not being used and the cold weather -- going from a typical ~41 mpg (hilly back-roads commute) down to ~36 mpg;
    • I got the red triangle of doom last week, and dealer diagnostics said the hybrid battery had deteriorated. For new battery, installed, they would charge ~$4,000.
    My intention with this vehicle was always to have driven it until it was dead, but I had imagined that that would be many miles and years from now... I'm not sure what other maintenance costs I might face if I go ahead and get the a new battery, so I'd be grateful for any advice on whether to replace the battery, recondition it, or move on to some newer vehicle. A significant factor for me is minimizing cost of ownership, but I'm not sure where the sweet spot ends for a Prius between cost of depreciation vs. cost of maintenance.
    Peterhans and jeff652 like this.
  2. JC91006
    16,482
    8,400
    Since you've already brought it to the dealer for diagnostics, call Toyota corporate and ask them for a goodwill warranty on the battery. You have so few miles, they may just help you pay a big portion of the replacement battery cost.
    I would not junk the car, it's just barely broken in. If you decide to sell it, I may sell one of mine to buy yours....It's like a new car lol
    uber2016, Kent77 and biglew8 like this.
  3. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    I think the battery may have died because it wasn't used enough. I know that sounds odd, but I have a 2004 with the original battery and 282,xxx miles. I get anywhere between 42-49 mpg consistently. I have no idea what I plan to do when the battery finally goes, but if I were you, I would go to the second hand market. You will have do some research in your area and see if you can get a salvage unit. Thre are places that come to your car and do a swap out for ~$1,200-$1,500. Good luck. If the other parts of the car are in good shape it would be a shame to junk it.
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Kent, if Toyota won't help with the battery I would shop the local dealers and get their prices for installing a new pack. I know the car is a lawn ornament but if the price difference is significant it may be worth the tow.
    Very low annual mileage is a problem. Are you able to plug in a battery tender?
    Kent77 likes this.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    It would be a shame to junk this car. It certainly has more life left in it.
    I'm curious about the events leading up to the triangle of doom's appearance. I'd be happy to talk with you to figure out what to do or offer some advice. Just give me a call at the phone number in my signature.
    It sounds like your Prius sits unused for long stretches at a time. This is especially hard on an older Hybrid Battery, even if that battery has low miles on it.
    I love hybrids and my livelihood depends on them. But I've got to be honest that in some situations it make sense to own a non-hybrid instead of a hybrid.
    knettle3 and Kent77 like this.
  6. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    There is a guy I found on eBay that covers the MD, VA, DC, PA areas and will rebuild your battery for 599. Never contacted him or anything though because I got an entire used unit.
    iPhone ?
  7. bisco
    49,504
    if you're averaging 5,000 miles per year, i would replace the battery and sell it, looking for a corolla and etc.
    that being said though, it will probably last another 10 years.
  8. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Well, you did as you intended however the event occurred much earlier than you anticipated. Hope you didn't pay too much for it.
    Anything else wrong with it? If not, here's WWJ do.
    Definitely try to get Toyota Corporate to fork over some goodwill money to install a brand new HV pack. Then you would be able to sell it close to the top end of the KBB price range or you could just keep it for another 10 years assuming that you continue to have no other major maintenance headaches to deal with. Gen 2 Prius' with 150K miles and more tend to burn oil which requires that you periodically top off the oil between changes. There are other minor issues that will probably need repair at some time like the HV inverter electric water pump, the gasoline engine water pump, and possibly the coolant control valve. Each of these are relatively easy DIY repairs. Later on you might have to contend with more pricey repairs like the brake accumulator pump, wheel bearings, the MFD, and the combination meter.
    If Toyota won't help you out with a new HV pack, the decision to sell or keep it is clearer. You don't drive enough miles per year to keep the HV pack happy. Once an original pack dies, it can be resuscitated but never fully brought back. And it will fail again within a few years and in your case probably much earlier. You could install a rebuild like a Dorman but you'd likely have the same problem - the pack will die on you and you or a mechanic would need to swap in another after a year or so. That would suck in the middle of winter. Your best option is getting the lowest cost rebuilt pack you can buy with a transferable warranty, detailing your car to make it look its absolute best and sell it. You might get about 2/3 what it's worth that way. Then you could buy something more
    suited to the relatively few miles per year you drive.
    Best of luck to you.
    Kent77 and JC91006 like this.
  9. Kent77
    Philadelphia, PA
    Thank you to everyone who responded—really helpful to get the perspective of people who know these cars (much) better than me.
    Asking for a goodwill warranty is a good idea; I’ll definitely try that and report back. Otherwise, some shopping around sounds in order.
    The rest of the car is in good shape so far as I know. Really odd that not using it enough is a problem, but there we are. Most weeks I do about 75 miles in commuting, but just occasionally (unfortunately coinciding with the winter) it lies dormant for a few weeks. I have on-street parking, unfortunately, so routine use of a battery tender is not possible.
    I take it that trying to recondition after a P0A80 and P3000 is probably pointless?
  10. trentofdestiny
    1,104
    225
    Harrisburg, PA
    Yes those codes mean replacement of one or more modules or the pack as a whole is likely necessary.
    iPhone ?
  11. bisco
    49,504
    if you want to talk to the expert: @jeff652
    jeff652 likes this.
  12. jeff652
    jeff652 Senior Member
    606
    623
    Idaho
    Maintaining the hybrid battery charge is important, especially when the car is not driven that often. We have hundreds of snow birds and other low vehicle use customers using our systems to keep the battery charged and in good operating condition. Not being driven regularly is hard on the battery, but with regular maintenance the battery will last much longer then if it is ignored.
    As you already have the P0A80 and P3000 there is a 50/50 chance a module or two will require replacement. However since your failure is due to non-use, there is also a good change that simply cycling the pack and restoring a balanced charge level across the cells will be enough to recover the pack and return it to operating condition.
    The lowest cost option would be the Prolong Value Reconditioning Package. It has everything needed to perform unlimited battery maintenance at home for the rest of the life of the vehicle. It does use the manual light-bulb discharge process:
    Prolong® Value Reconditioning Package - Hybrid Automotive
    If you don't want to mess with the light bulbs and want the easy of use that our new Prolong Battery Discharger provides, then I'd recommend the Prolong Deluxe Reconditioning Package:
    Prolong® Deluxe Reconditioning Package - Hybrid Automotive
    djasonw, Raytheeagle and bisco like this.
  13. bisco
    49,504
    thank you jeff.(y)
    jeff652 likes this.
  14. Tideland Prius
    16,158
    Yeah it really depends. If you don't drive often, then a new battery might not be worth it. If you are using it regularly and the car is in good shape (sounds like it is), then you essentially will have a new car for $4,000 (76,000 miles is nothing for a 10-year old Toyota). I would also shop around and see what other dealers are charging for a new battery. In theory, they should be the same but it seems a bit expensive considering we were quoted $3,500 Canadian dollars (and the exchange rate is 75 US cents to our dollar).
  15. Kent77
    Philadelphia, PA
    Thanks again everyone. I called Toyota USA and they kindly offered $2,500 in assistance toward a new battery; combined with a procrastination-induced drop in price from the dealership then the total cost including the diagnostics dropped from $4,300 down to $907, a huge savings. I would've preferred not to have had the problem in the first place, but at least I should be good for many years to come provided nothing else goes wrong!
    srellim234 and Vkguda like this.
  16. earls1
    earls1 New Member
    Oakland
    HI Kent- I just experienced almost exactly your situation. My prius only has 77k and the hybrid battery is dead. Can you please tell me what exactly you said to Toyota USA that led to them providing your $2500? I would be most grateful for you sharing your strategy/approach!
    Peterhans likes this.
  17. Kent77
    Philadelphia, PA
    Hi earls1, I wrote a bit more about it in the thread over here: HV Battery Goodwill Warranty Listing - Toyota Prius USA | Page 4 | PriusChat
    Basically I called 800-331-4331, option 4: “Concern or problem with vehicle or dealer”, explained my situation (and that the dealership had suggested I call), dropped in there somewhere that we also had another Toyota vehicle, and was super-polite the whole way through. The agent I spoke to asked if I was looking for assistance, I said yes, and she said they would look into it and call me back in a few days, which they did. I didn't chase or have to be pushy.
    Good luck!
    Peterhans and fotomoto like this.
  18. stevejenks
    stevejenks New Member
    kekaha hi
  19. stevejenks
    kekaha hi
    i had my hybrid battery rebuilt 3 months ago at the collage here cost 1200 . do some reaserch before you pay dealership cost
