Hybrid Battery Drains Upon Startup
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by mdmllins21, Jun 9, 2020.
  1. mdmllins21
    mdmllins21 New Member
    United States
    Background: 2016 Prius two with 40,000 miles recently purchased a couple months ago.
    The potential issue I am seeing is when I start up the car after sitting at least 3 to 4 hours the battery will drain to 2 bars quickly (within a couple of minutes). It charges back up normally (not too fast) after driving for 5 to 10 minutes. I then don't really see any rapid fluctuation after that. I've owned the Gen 3 prius for 5 years and never saw this happen. I am wondering if this behavior is typically seen in a Gen 4. If not, any suggestions on what it might could be. Thanks!
    This may or may not be relevant. After the first week of purchasing the 12V battery went out (sat in the driveway for 4 to 5 days) and was replaced (reimbursed by dealer thankfully).
    52,375
    welcome!
    seems normal to me. is this during warm up? the software protects the engine by using battery if available.
    from how many bars is it dropping to two?
    is the a/c on?
    amos likes this.
  3. krmcg
    2,592
    2,392
    Whittier, CA
    Have you calculated the MPGs? Low mileage value would be a sign of a problem more than the battery bars...
    amos likes this.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I believe there were two styles of traction battery in the 2016 depending on model: a NiMH and Li-Ion. Mine, the Three Touring, has the Li-Ion battery, and with just over 30,000 miles now, the battery level is rock steady. No rapid depletion at all. We had a Gen 2 with NiMH battery, and it began rapid depletion after several years and over 100,000 miles. This was a sign the battery was losing capacity and maybe balance of the cells. There are cell balancing equipment and procedures for NiMH batteries that you might want to investigate, if it turns out you have that style battery.
    amos likes this.
  5. mdmllins21
    United States
    I appreciate the responses! Yes this is during the car first starts up. The car usually drops from about 6 bars. The car A/C is usually turned on when it the car started up.
    The MPGs are where they should be (between 55-60MPG)
    bisco and krmcg like this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I wouldn't rely on the accuracy of the HV battery gauge.
    fotomoto and krmcg like this.
  7. bisco
    52,375
    sounds like all is well
    krmcg likes this.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    It did. TONS of threads on this over the years. I can also vouch that other hybrids do this too including plug-ins.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    This sounds totally normal. As previously mentioned, the car is borrowing from the battery and babying the ICE when you start it up. Add to that the A/C load on a hot cabin and you'll suck lots of juice from the battery which the ICE pays back after it hits a more normal operating temperature. You'll see evidence on the instantaneous MPG display. When it starts out, it'll be ridiculously high. Then it'll be crazy low while it puts electrons back in the battery. Then it'll level off.
    #9 jerrymildred, Jun 11, 2020
    robsnyder20, amos, Princer and 2 others like this.
  10. fotomoto
    5,639
    3,815
    So. Texas
    Now combine this with regular daily short drives and it equates to A) very low mpg (for a hybrid) and B) hard on a small battery. Once I learned this, swapping to plug-ins was the solution for me.
    jerrymildred likes this.
