Hybrid battery drains while driving until car stops
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 04.ATX, Jul 16, 2017.
  1. 04.ATX
    04.ATX Junior Member
    Austin
    The basic scenario is:
    1. while driving, the gas pedal starts to feel weak
    2. the hybrid battery drains rapidly
    3. the car stops
    When this happens my "solution" has been simple. I turn off the car. I turn it back on the engine starts running and the battery starts to charge. When it gets up to 3 bars I start driving and I usually don't encounter this problem again for a few months.
    Coolant levels are fine, and the inverter is flowing on ready. Getting a new 12-V battery didn't seem to prevent this from happening again. Check engine light goes on and off randomly but not in conjunction with this issue. Not sure what else I can check that may explain this. I've had my 2004 for about two years now (new hybrid battery installed prior to purchase). This has happened about once every few months- but it happened twice this week.
    Suggestions appreciated!
  2. Mendel Leisk
    40,586
    So the engine's not running, and the car's completely reliant on the hybrid battery. I'd get the codes read at a dealership, and post them.
    04.ATX and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Was it a brand new battery from Toyota or a "new to the car" battery from Dorman or a local rebuilder?
  4. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    Read the fault codes. Very likely there is some code that (points to what) caused engine to stop running.
    If you want to read the codes yourself get mini-VCI it’s cheap and can read all the codes and do other stuff on Toyotas. But you do need a windows laptop with it.
    04.ATX likes this.
  5. 04.ATX
    Austin
    Dorman installed 10/2015
    Raytheeagle likes this.
  6. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    What's the warranty?
    After reading the codes that the car displays, I would start engaging Dorman as your pack sounds like it is on the way out.
  7. JC91006
    16,674
    8,519
    2 years on a Dorman pack is very good nowadays. As the battery packs get older and older, from high mileage cars, rebuilt packs will now rarely see 2 years of service. You should check the codes and contact Dorman if the battery has failed.
  8. 04.ATX
    Austin
    Exactly. Initially I thought that the engine was overheating but now it just seems random. Yesterday it occurred at night when it was cool, less than 5 minutes after starting the car.
    Just ordered mini-VCI- thanks for the tip!
    Oh wow... so if that's the case, what is the best option? Seems like a waste of money to buy a Dorman every two years...
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    The engine is very low on oil
  10. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    You have some decent resources here @ericbecky may be able to help you.
    To answer the question, The best solution is generally the "new" OEM Toyota batt, otherwise the refurbs have less long life. when I say "Best" I mean best battery...the actual choice will depend on owners needs as far as speed of repair to get car back, and cost.
  11. Mendel Leisk
    40,586
    Isn't the issue that the engine isn't running.
  12. edthefox5
    10,096
    4,831
    Clearwater, Florida
    "Check engine light comes and goes"
  13. 04.ATX
    Austin
    The engine battery draining has happened a few times this week. Finally read the codes:
    B2795 immobiliser unmatched key code
    B1271 gateway combination meter ecu communication stop
