Hybrid battery fail
Discussion in 'Prius c Main Forum' started by leifanders, Jul 18, 2020.
  1. leifanders
    leifanders Junior Member
    22
    US
    Hello. I recently got the dreaded P0A80 replace battery pack message for my 2012 Prius c but I thought I'd only run of gas and it shocked the system. Car still runs but only on gas engine for now. Is it safe to pull the high voltage plug and then put it back in to possibly reset the system? Or am I doomed to replace the thing (only 135k miles).
    Any help in this is much appreciated.
  2. Mendel Leisk
    41,893
    Better chance would be to disconnect 12 volt neg cable for a few seconds, as far as memory reset. Still, not sure that it would help. Maybe.
    It might be you WERE running out of gas, and the Prius c allows the car to make extra use of hybrid battery in that circumstance, run it dangerously low? Just a nasty thought.
    I've read about that happening with 2nd gen, fwiw.
  3. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    The computers that manage the hybrid system (and manage the stored diagnostic codes) are run from the 12v electric system, not the high voltage one.
    So theoretically you could reset the 12v system to blank out the error codes and ask the car to behave normally again. It has worked before. I don't usually recommend trying this without first getting a real diagnosis from somebody who actually knows hybrids. If you're going to game it, it's good to know which game.
    Probably the cheapest way out is to buy a used genuine battery parted out of a wreck.
    Get the youngest one you can find- these batteries are more sensitive to age than mileage.
    52,380
    the fact that the hybrid battery is starting the engine tells you something...
  5. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    My suggestion is to get an OBDII bluetooth adapter and then run an app such as Dr. Prius that can give info about your battery. If just one cell is bad, maybe you can replace that one. People on the forum (myself included) have criticized playing "whack a mole" by replacing individual cells, but your battery is not super old, so replacing one might keep you going for quite a while.
    Have you been using your C very little during the Covid crisis? Using a Toyota hybrid regularly helps keep it healthy. I take my old Prius out for "exercise" a couple of times per week.
  6. leifanders
    22
    US
    I have been driving it everyday yes. Same as usual maybe a little less because of covid. Thank you for the reply. I was thinking of disconnecting the 12volt then reconnect maybe that will reset it?
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    When you ran out of gas you then used the hybrid battery to get you where you needed to go and that flogged the battery pretty hard. You ran it really low on its charge level. It may have gotten so pissed at you it threw a death code for the battery. Hopefully you can clear it.
    Don't ever run out of gas in a Prius it can be really expensive.
    The quickest way to kill a Prius is to stop driving it. Its hard on the hybrid battery and the 12 volt battery also for the car to just sit there. I make my wife take out her G2 and drive it everyday.
    G2 Hybrid battery's on this site are dropping left and right because the car just sits there.
    Aaron Vitolins and leifanders like this.
  8. leifanders
    22
    US
    Thank you for the reply. So it turns out I just disconnected the 12-volt battery and then pulled the safety plug on the hybrid, waited 15 minutes and it started right up with the hybrid system working just fine. I'm amazed and appreciative of all the help I've gotten on here. Thanks again
  9. edthefox5
    10,096
    4,834
    Clearwater, Florida
    I wouldn't bother pulling the orange safety plug that wont reset anything but pulling the 12 volts will.
