hybrid battery health check
Discussion in 'Gen 3 Prius Main Forum' started by MeGuinness, Jan 23, 2017.
  1. MeGuinness
    MeGuinness Member
    217
    78
    UK
    What software/hardware toyota dealers use to do a hybrid battery health check?
    Thanx
    49,469
    toyota tech stream software, on a laptop.
    Raytheeagle likes this.
  3. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Is a automated process ? As I'm looking at the techstream software but cannot see such setting in the menus.
  4. Mendel Leisk
    38,718
  5. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Yes ,not servicing at Toyota anymore , nearly 200k on the clock , trying to find what can give error code p0a7f but Toyota got no idea what can be ,they suggested to check HV fan and told me they can only do the health check after about 400 miles from when the error as been cleared ,the error keeps popping up just when I want to take to Toyota for the check ,so if I can do it myself would help if is a automated test. 1485195506512.jpg 1485195512620.jpg
  6. jerrymildred
    jerrymildred Senior Member
    11,511
    14,111
    Tampa, FL
    Have you cleaned that fan and you're still getting the code?
  7. Mendel Leisk
    38,718
    Even though that fan is kinda ugh, definitely needs a cleaning, it's better than the Luscious Garage horror story pic's. Run a duster wand through all the ductwork too. Then compressed air everything.
  8. MeGuinness
    MeGuinness Member
    217
    78
    UK
  9. bisco
    49,469
    we don't have the health check here, so idk what's involved. i don't think there is an automated program in tech stream. the most i recall reading about is putting a load on the battery and looking at the variance in cell voltages.
  10. MeGuinness
    MeGuinness Member
    217
    78
    UK
    The Toyota guy showed me a health check print out that failed the test because the errors codes that were cleared previously did still showing and it needed to drive about 400 miles without showing any errors so that the health check could complete the test .....
    This is the third time I asked....I got the same answer...,so I believe there must be a software or a setting on techstream that will run the test and then make a print out of the outcome.! Got to look for this printout between my papers ...I had one done on last time I serviced the car at Toyota
