Hybrid battery. I tested all modules, they are good, but keeps discharging.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Luis Lednick, Aug 7, 2021.
  1. Luis Lednick
    Luis Lednick New Member
    san diego, ca
    Hi everyone,
    I'm new here. Nice to e-meet everyone.
    Question: I disassembled the battery pack and tested every cell ( see pic ), but still keeps discharging.
    The scanner gives me the code ( see pic ).
    So, when I unplug the 12V battery for 2min and plug it back in, the message goes away and seems to charge the battery from 2 bars to full in about 5 minutes.
    ** From the forums I've ready, I was expecting to see a bad battery, like with 5V that had to be replaced.
    Any thoughts? Thank you,
      File size:
      26.7 KB
      File size:
      81.9 KB
      File size:
      139.3 KB
  2. PriusCamper
    PriusCamper Senior Member
    11,092
    4,515
    Pacific Northwest, USA
    Next step is to measure how much voltage drops when you attach a 12v 50w bulb (can use car's headlight bulb if its halogen) to a module for 2 minutes.... The bad modules will lose much more voltage than the good ones.
  3. JC91006
    16,480
    8,397
    Prius has a 10 year / 150k miles warranty. If your car is a 2014 and under 150k miles, you are still under Toyota warranty.
    If you take those voltage measurements after letting the battery sit for 1 week, the weaker modules will measure much lower. As it looks now, the battery pack is not very balanced and you may have a weak/failed module in there. Measurements taken after 1 week usually can identify the bad ones.
    SFO likes this.
  4. douglasjre
    douglasjre Senior Member
    1,872
    651
    Orlando, FL
    Techstream?
  5. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    o_O
  6. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    Only if the vehicle originally from Cali, New York state
  7. douglasjre
    1,872
    651
    Orlando, FL
    How about if it became registered in California now
    Banksy likes this.
  8. Tekken
    Tekken Member
    257
    77
    No, my 2013, 1st owner originally from Kansas city. and it has been Cali registered since 2018. Last ECU soft upgrade, the manager pull out the policy on this vechile doesn't apply as 150,000 miles or 10yrs Hydrid battery warranty
  9. FrankB
    FrankB Member
    117
    53
    Also check that no cells are shorted to the chassis. Measure the voltage from each cell to the chassis, they should all be 0 when the bus bars are removed.
  10. bisco
    49,438
    welcome!
    corrosion
