Hybrid battery is imbalanced
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jama707, Aug 20, 2022.
  1. Jama707
    Jama707 Junior Member
    SACRAMENTO, CA
    I did a Dr prius check on my prius 16 which resulted with 72% charge. But it showed 1,2,8,9 blocks as imbalanced. How there could be such significant difference? I don’t have any codes from hybrid battery but the mpg is around 35. What’s the normal cell/block voltage should be on Gen 4?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Your car has 28 modules, just like the Gen 2 and Gen 3, but the Gen 4 does not monitor "14 blocks" like those Gens, it only monitors 9. This results in the voltages being double for 5 sensor points. The voltages in your photos are normal. Apparently Dr Prius doesn't account for the difference between Gen 4 and previous models.
    alanclarkeau and Jama707 like this.
    52,396
    how many years/miles have you owned her?
    how many miles on her?
    have the mpg's always been so low?
  4. Jama707
    SACRAMENTO, CA
    I bought it few months ago from an auction and it had 332k miles - I had to get engine leak fixed and also mechanic replaced the engine control module from junk yard donor car. Before these reps it was giving a decent mpg any around 45.
    And right now if I drive at night without ac on - it’s giving a good mpg. But when Ac is on its constant battle at 35 mpg. The ac is not cold enough as well. So maybe that’s also contributing to mpg deterioration?
  5. Jama707
    SACRAMENTO, CA
    Thank you. Perhaps I can cross off the hybrid battery.
  6. bisco
    52,396
    could just be the summer heat and ac use. prius takes a big hit, especially on an older battery
  7. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    I emailed him with the same question. He said it was because the outer blocks had half of the sensors to save money. He said he would also update the application to not show this as defective on future tests
