Hybrid Battery Pack Deterioration P0A7F
Discussion in 'Gen 3 Prius Main Forum' started by Kiwibird, Apr 6, 2024.
  1. Kiwibird
    Kiwibird Junior Member
    55
    Sydney
    i-Tech
    My car is Toyota Prius 2010
    Done 252000klm
    I get the code P0A7F and I keep clearing it and drive, the milage I am getting about 500klm from a full tank.
    Is the milage normal?
    Also, can I just replace the bad packs in the battery? (From 5 to 10)
    Is this a straight swap? I have a camry 2015 complete good battery pack, can I use the cells from Camry to Prius?
    Thank you guys
    49,693
    you really need to determine you klm/gallon when you fill up by dividing klm by gallons.
    going by the tank isn't very accurate.
    you can swap modules, and it sometimes works for awhile, but you're better off balancing the pack for a little better reliability. that takes time and patience unfortunately.
    idk if camry modules are the same or not.
