Hybrid battery pack going out
Discussion in 'Gen 2 Prius Main Forum' started by Nina Ezell, Jun 29, 2020.
  1. Nina Ezell
    Nina Ezell New Member
    Salisbury
    My hybrid battery pack is going out. The vent in the backseat started running that I’ve never heard do the other day and all of the check engine lights came on. I took it to get a diagnostic scan and they confirmed it was the battery pack. I don’t have a lot of money to fix this issue. Is there anything I can temporarily do to fix the problem short term?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    You can see if cleaning your HV battery fan will offer a bit of time, there are plenty of DIY and how-to's out there.
    Did you have the OBD2 scan performed at a dealership, if so then they should've supplied you with the retrieved codes (DTCs).
    Please post the codes (DTCs) here for additional advice.
