Hybrid battery problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dominicsavio, Jun 27, 2009.
  1. dominicsavio
    dominicsavio New Member
    83
    Folks,
    My hybrid battery never gets fully charged while driving. I've never seen it fully charged (green) and only very rarely seen it one level below fully charged (also green). Most times, it is blue but I've also noticed it drains pretty quickly (city driving or starting up the next day) --> usually half or sometimes less charge.
    My car is '06 with 28000 miles.
    Any idea if this is a problem?
    I do have the extended platinum warranty.
    Would be good to get some input...
    Thanks
  2. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    Nothing is wrong.
    That's what you are suppose to see.
    Being at 6-bars most of the time is what contributes to battery longevity.
  3. Patrick Wong
    18,200
    6,492
    Your car sounds normal. If you want to see eight green bars you'll need to find a mountainous road where you can mostly coast downhill ~1,000 ft elevation drop or more.
  4. dominicsavio
    83
    Okay, thanks for the info. It's good to have perspective. I usually have 5-6 bars (blue; assuming 8 is the max which I think it is but am not entirely sure)....
    No my next attempt is to see how I can cross the 60 MPG barrier. No matter what I try, I'm averaging about 57-58 (SE Pennsylvania, warm weather, No AC so conditions are ideal). I
    I do P&G whenever I can, minimize EV mode, etc but I guess I need to do more. 've started reading through the finer technicalities...
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The control system works very hard to keep the battery exactly where yours is. The car needs power from the battery when you ask for it, but has to save room for regenerative braking. That's why it stays toward the middle top of the range.
    Tom
  6. richard schumacher
    7,664
    1,043
    United States
    Do not hesitate to use the air conditioner. The battery system is cooled using cabin air. If you are too hot while driving then the battery system may be also, which will reduce MPGs.
