Hybrid Battery Reconditioning/Replacement Options?
Discussion in 'Gen 3 Prius Main Forum' started by stokesey, Nov 12, 2024.
  1. stokesey
    stokesey Junior Member
    49
    Southern Cal
    So I've read up on grid chargers, refurbished hybrid batteries, and the hybrid battery replacement process. Also watched several great YouTube vids on battery reconditioning and cell replacement. It seems that not all of the cells fail, but the system can't charge cells individually. Therefore the charging system can only charge the hybrid battery until the good cells are at full capacity (~7.2Ah if I gather correctly). This means that the worn cells lag behind and pull charge from the neighboring cells, diminishing the total battery capacity.
    Full charging and discharging cycles seem to have a rejuvenating effect on the worn cells, as long as heat is contained. But several pros recommend replacing cells that can't sustain around 5Ah since batteries can be fickle.
    I've got a Prius that sat for 2 years and I'm wondering what my best course of action will be. A grid charger could be an easy fix, but should I go into the battery pack and balance all of the cells? Of course I can do some voltage measurements and maybe run Dr Prius once I get the car running.
    Also, several of the balance chargers used on YouTube say expressly "NOT for use with hybrid battery packs, will cause damage". So can anyone recommend a balance charger that is suitable for the task? Or, should I just buy a refurb battery and drop it in?
    Thanks
  2. ASRDogman
    ASRDogman Senior Member
    7,046
    3,692
    Get the Prolong system. It has the PROPER charger and discharger and is the safest way to do it.
    You may be able to revive it. If you can't, there is no sense in playig wack a mole with trying to swope
    out blocks... Unless you have days and days to play with them.
    But if you want it "fixed", try the Prolong system, or replace it with the Sodium Pack...
    50,869
    it's a big expense to gamble on vs putting the money into a new battery.
    what year and how many miles?
  4. stokesey
    49
    Southern Cal
    Its 2010 w 120k, low miles so I feel like its worth saving. I'm familiar with the head gasket issues but I'm confident that I'm out in front of the problem and can mitigate it.
    Refurb battery is about $1200 from what I've seen so probably worthwhile if I do the labor. Looks like no coding, just plug n pray?
    On the other hand, I won't mind having the grid charger around. If it can help condition the battery for longer life its probably worth it.
  5. stokesey
    49
    Southern Cal
    Thanks for the advice. If the Prolong can bring the battery back from the dead I'll try it. Just wasn't sure that it would revive a totally dead hybrid battery.
  6. james wang 20
    james wang 20 Junior Member
    62
    fiji
    The grid charger charges with a low current for a long time. It takes advantage of the charging characteristics of nickel-metal hydride batteries to overcharge with a low current, which can help your battery restore balance. However, if the capacity of the cells itself is lost too much, this kind of charging cannot solve the problem. The problem is, you can find a cell with a capacity lower than 2ah and replace it. I don’t know the threshold value for Prius to detect battery capacity. I can only tell you that battery cells higher than 2ah seem to work very well in the car. The larger the capacity, the better. good.
  7. stokesey
    49
    Southern Cal
    That makes sense. Can the grid charger also cycle charge with discharge, cool down, and recharge, or do I need to do that manually? I've seen a few people saying if the car is in neutral it'll drain down the hybrid battery slowly. Or maybe just driving slowly in EV Mode will also accomplish that result?
    Thanks
  8. james wang 20
    62
    fiji
    I have never owned a power grid charger, and I don’t know if it can automatically discharge. I only have a regulated power supply and a homemade discharger, and it needs to be done manually, which is very time-consuming. If you don't like this, you can also buy a charger for model aircraft, which can charge and discharge. The end of charging and discharging is automatically detected, and you can also get capacity information.
  9. bisco
    50,869
    check hybrid automotives website. should have all the info you need
    Brian1954 likes this.
  10. james wang 20
    62
    fiji
    When the hv battery is in the car, you can turn it on and it will slowly discharge. Turning on the air conditioner will accelerate the discharge, or slow EV driving will consume power. Due to Toyota's charging and discharging strategy, it cannot drain the battery. If your hv When a battery has damaged cells and you must open it, you have the opportunity to drain it through a slow discharge, which may help alleviate the memory effect of NiMH batteries.
    stokesey likes this.
  11. stokesey
    49
    Southern Cal
    That makes sense, Toyota doesn't want the battery dropping too low, as it could brick the car. It looks like any procedures done to the battery in the car will be approximate, and won't allow servicing of individual cells in the hybrid pack. It remains to be seen just how important it is to service them individually.
    I'm familiar with batteries of each chemical compositions having memory. If I recall, NiMH behave differently from Lithium and Lead-acid batteries. Operating temperature also has an impact on this, colder weather means lower capacity and shorter memory.
  12. vvillovv
    vvillovv Senior Member
    4,316
    1,495
    NY
    You'll find out more about the pack once you get it open and start taking voltage readings. 7.4 volts is a modules nominal rating and they charge a few volts higher somewhere around 8.5 to 9 volts.
    There are 6 ( 1,2 volt (nominal)) cells per module and 28 modules in the Gen 2 and 3 Prius hybrid battery pack.
    You have to be careful when choosing a charger to make sure it will charge NiMH batteries, since many newer chargers will only charge lithium. The charger must also be rated for at least 6 NiMH cell packs, but most that come with NiNH settings already support more than 6 NiHN cell packs, still it's in your best interest to make sure.
    Since reading above it looks to me like you might have an interest in working on modules individually.
    Here is a link to a charger / discharger that is used fairly widely by priuschat members and has some decent youtubes on how to use it too.
    EV-Peak CQ3 100W x4 AC/DC Quad Balance Charger
    With this charger you can cycle 4 modules at a time. Some even have several of these chargers.
  13. stokesey
    49
    Southern Cal
    Great info, thanks. That's the charger I've seen on the videos I watched. Good to have a domestic source for it. 100W seems a little underpowered but I guess you just buy 4 of them and work slowly. Slow charging is generally better for the cells and creates less heat anyway.
    A data point on my (other) working Prius's EV pack is that it seems to drain down to half full when the car is sitting overnight (according to the dash gauge). That seems to be quite a bit of discharge. Probably some cells need conditioning or even replacement.
    So I guess the total voltage out of the EV pack is 208V. And the inverter converts that to whatever AC voltage to power the EV motor? Dangerous stuff:eek:
  14. vvillovv
    4,316
    1,495
    NY
    That's called self discharge.
    Measuring it is one of the ways to predict how well a pack will work after it's been cycled and balanced and reinstalled in the car.
  15. stokesey
    49
    Southern Cal
    I'm guessing I'll need to take a few measurements of this discharge as there are a lot of variables, such as air temperature, alarm on/off, and amount of time charged before rest. Maybe others I am not think of...
  16. vvillovv
    4,316
    1,495
    NY
    There are many theories about how best to run a cycle on a set of 6 cells in a prius NiMH module.
    If slow charging a module at below an Amp, - timed charging - is one recommendation. If charging that way, you want to get a reading of the charges ending voltage and / or the voltage when it stops increasing during the charging session. Many say that 350 mA is fairly safe to let a 7.4 volt nominal NiMH module charge for 24 hours, as long as the module temps are monitored and or fan cooling is used effectively.
    Resting time is not nearly as important as some of the other settings, it lets the cells in the module drop their voltage from the the high point to where the voltage starts to settle into the modules normal rate of self discharge. Self discharge is another strong indicator of how healthy a module is. Monitoring a module for 24 hours, every hour or so, after a charge session, will give a general idea about the modules rate of self discharge. A long time monitoring, every day after the first 24 hours, or however long it takes to cycle all the modules in the pack, will give a much stronger idea of how the pack will behave when it's in the car.
    If you have a charger/discharger that can connect to a computer and also has a decent app to monitor charge/discharge cycles, you can see those and sometime a few other important variables graphed visually, but it's not somethings that is always obvious the first couple or even the first hundred times looking at the graphs. Learning the ins and pitfalls of cycling modules is a process, until the modules stop responding to the cycling, which will happen eventually. Temps below freezing are no walk in the park for hybrid batteries either.
    Temp:
    most definitely don't want to charge near freezing or above 100 F. ( 60 F ) is pretty close to optimal for NiNH chemistry cells from my experience. I've seen modules take a few more watts during charging at 50 F but it falls off rather fast when temps drop below that, ( Reducing the charge voltage ) and letting charge cycle run for a longer time at ( lower voltage ) is one way around the low temp barrier, but you want to proceed with caution when you do that, especially with older, less healthy - cells modules packs - which ever way you are charging / discharging them. This is also true of higher temps above 100 F, but because so many have early degradation rates with local high temps, many have named High Temps as the No 1 killer of hybrid packs.
    #16 vvillovv, Nov 30, 2024
  17. stokesey
    49
    Southern Cal
    Great info, thank you. For anybody looking for balance chargers on the cheap, I found a Chinese source on dhgate: https://www.dhgate.com/product/parts-accessories-imax-b6-v3-80w-6a-battery/882906760.html
    I have no idea about the quality of this product yet. But it's in stock and higher China tarrifs are coming soon. Will advise the forum here about my experience. I ordered a couple units figuring some won't work right. I have some ebikes and electric scooters around that I'll experiment on before I pull the Prius battery.
  18. stokesey
    49
    Southern Cal
    This guy seems to be super informed on Prius traction battery balance charging and he uses close to the same chargers I ordered:
    Nice tips on using a headlight bulb for discharge cycles and how to reset the Prius hybrid battery warning on the dash. I might use lower amperages to charge my modules as I'm just learning about it. Better to not heat anything up too much.
    I figure I'll have a few spare modules on hand to replace any that are toasted and just won't hold spec capacity and voltage.
  19. vvillovv
    4,316
    1,495
    NY
    Nice set of posts ! Caution using your chargers on ebike and scooter packs that you have not already modified into smaller sub packs. The lithium (cells in series) pack size is limited to 6 cells in series and most ebike and scooter packs are way more than that.
  20. stokesey
    49
    Southern Cal
    Thanks for that advice. I believe you're supposed to use a breakout board for charging lithium batteries. I'm working on getting the right ones for my applications, there are many different variants. But ideally you connect to the wiring harness on the BMS (battery management system) and then your charger balance charges each cell individually to your specified voltage and amperage.
