Hybrid battery refurbish
Discussion in 'Gen 2 Prius Technical Discussion' started by marhuu, Apr 3, 2024.
  1. marhuu
    marhuu Junior Member
    Chicago, IL, USA
    Hi All,
    I got a question when I balancing my modules. Most modules are refurbished as expected, the discharge capacity increase as cycles go on. But there are several module behave weird. The discharge capacity was good at cycle 1 or 2, then in later cycle (3-5) charging stopped at very low capacity then following discharge capacity of course is lower too. my questions is why these several module behave differently than other good ones. why charging stopped at very low capacity?
    My setting is below
    Capacity cutoff 7250 mAH
    Charge 2A
    Discharge 1 A/6V
    DCHG/CHG 5
    see below the discharge/charge data
    Discharge/Charge
    Cycle 1: 2500 mAh/7250mAH
    Cycle 2: 5500 mAh/680 mAh
    Cycle 3: 564 mAh/360 mAh
    Cycle 4: 300 mAh/590 mAh
    Cycle 5: 550 mAh/720 mAh
  2. BrokenPipe
    BrokenPipe Junior Member
    32
    NorCal
    Meg&Bear likes this.
