Hybrid Battery Repair - Prius 2011
Discussion in 'Newbie Forum' started by AKSL, Nov 1, 2020.
  1. AKSL
    AKSL New Member
    Sri lanka
    Hii all,
    Please help me on this..
    1. Can this battery be repaired?
    2. How many cells need to be replaced and that are they?
    3. Is it worth repairing?
    Thanking you..
  2. PriusHead05
    PriusHead05 Member
    304
    87
    AKSL likes this.
  3. PriusHead05
    PriusHead05 Member
    304
    87
    Also, welcome to the chat!
    AKSL likes this.
  4. Garra671
    Garra671 Junior Member
    44
    Wherever
    What is he using too read the battery cells like that?
    AKSL likes this.
  5. vvillovv
    vvillovv Senior Member
    3,671
    1,299
    NY
    has the battery been grid charged recently?
    are there warning lights?
    DTC codes?
    #5 vvillovv, Nov 10, 2020
    AKSL likes this.
  6. AKSL
    AKSL New Member
    Sri lanka
    Battery is a reconditioned one.. have no idea what the milage is..
    Torque app.. with a Bluetooth OBD2 reader
    Not charged..
    DTC code is P0A80
    with ABS, Check engine, and other warning lights
    #6 AKSL, Nov 23, 2020
  7. PriusHead05
    PriusHead05 Member
    304
    87
    P0A80 means one or more of the cells have failed.
    AKSL likes this.
  8. vvillovv
    3,671
    1,299
    NY
    torque shows module pairs - 3 cells per module
    from the torque apps readings it looks like you'll need at least 7 modules. You wouldn't know which ones they are until you measure each module.
    Most likely are one (or both) module(s) of each pair of modules with readings of 15 volts and one (maybe both) module(s) of the pair reading 16.0 and 16;1 ......
    If you can get your hands on a grid charger you might be able to balance the the pack while you wait for new modules.
    It's a good idea to have a grid charger / discharger anyway if you plan to replace modules.
    oh yeah check your 12 volt batter too. It's a good first step to take concerning the other dash lights
    #8 vvillovv, Nov 24, 2020
