Hybrid Battery Replace 2005 Prius P0A80
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by barrystein, Jul 2, 2018.
  1. barrystein
    barrystein Junior Member
    26
    Oceanside, CA
    2005 Prius has 185,000. Car is throwing code P0A80. Dealer says it needs a new hybrid battery.
    Car is currently in OHIO.
    Does anyone know of a good after market source for hybrid battery near by.
  2. JC91006
    16,476
    8,393
    Aftermarket source will probably not be a very reliable source. If you're driving this car back to CA, the warranty on the aftermarket stuff will probably be very hard to claim when needed.
    ITBland likes this.
  3. barrystein
    26
    Oceanside, CA
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    A dealer price for NEW is likely close to $3000.
    You may as well call and ask.
    You could install it yourself for less.
    A NEW battery will far outlast a USED one.
  5. bisco
    49,380
    green bean is mentioned here quite a bit, do some googling and look for reviews. especially warranty service.
  6. ericbecky
    4,369
    3,217
    Madison, Wisconsin
    The only aftermarket NEW batteries are cylindrical ones similar to the kit made by CEBA.
    Everything else is USED.
    I am starting to see USED batteries that I installed in the past coming back after less than 3 years.
    Not good.
    Check with your dealer or independent shop to see how much a NEW battery costs.
  7. Wilsid
    Wilsid Junior Member
    91
    It's more than likely one cell went out, there 6 cells in a module,I bought a module out of a
    13 1 and a half years ago, car still going strong, module on ebay $36.50 free shipping
    that 05 isn't worth $3,000 I had the 04 apprised, $1750 I find if you don't work on
    these your self you can't aford one they are a money pit I talked to 2 employes at
    toyoda they said nobody that works there would have one , the only car they like
    is the camry
    #7 Wilsid, Jul 27, 2018
