Hybrid Battery sensor wire harness P/N
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mjoo, Aug 12, 2022.
  1. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Does anyone know the part number for the Hybrid battery voltage sensor harness? The harness I'm referring to connects the terminals (bolts) on the battery modules and also plugs into the voltage sensor module. I think they call it a wire frame on Gen2
    I tried finding the part(s) online and could only find the voltage sensor module.
    If someone could direct me to the Toyota part number that would be really helpful. Also once I know the name of this part maybe I can cross reference Gen4 vs Gen3. It would be nice if the Gen4 hybrid battery sensor harnesses were compatible with the Gen3 battery voltage sensor module.
    Thanks in advance.
  2. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
  3. Elektroingenieur
    2,515
    3,287
    Three Touring
    As shown in catalog Figure 82-01, Battery & Battery Cable, that wire harness isn’t sold separately as a service part. I’m sure it has a production part number, but you’re unlikely to be able to order one.
    On that page, if you click View More Images and then select the third image, you’ll see the harness is labeled N03, corresponding to a note: “This part is not supplied as an individual part, because it is difficult to keep the function/quality of part assembled.”
  4. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Ok, thanks for the knowledge.
    Is junkyard/ebay the only way to get them? I'm glad I have soldering experience.
    moto g power ?
  5. Mendel Leisk
    41,884
    Replicate it? Everything but the orange connector? Or is that crazy talk?
