Hybrid Battery Slowly Drains While Engine Running
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rishar, Feb 17, 2015.
  1. Rishar
    Rishar Junior Member
    US
    So this has happened to me a few times now in the cold temps. For my job I'm left to sit and idle every now and then after over an hour of driving.
    Normal
    I'll park my car, ICE will turn off, ICE temp at 195. Sit with heat on at 65 degrees. After about 10 minutes the engine temp will drop to about 110, which the ICE will start and warm up to about 135 and turn off. Hybrid battery stays above 55% and normally hits about 65% on every ICE start. (I have extra instrumentation installed to monitor)
    Abnormal
    Park car, ICE at 195. ICE never shuts off, RPM's sitting around the 900 mark. Hybrid battery slowly drains. When it does this I've tried turning the heat off. Nothing. I've attempted a shut down and restart. Still keeps doing it. The Hybrid Battery just seems to quit taking a charge at idle. After I've started driving again and come to a stop, it seems to return to normal.
    I've checked the internal resistance of the hybrid battery, all cells measure the same resistance and voltage so it seems to be fine to the best of my knowledge.
    Any thoughts on this would be greatly appreciated.
    Thank you.
  2. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    The battery might be too cold, so the car is trying to avoid using much battery power until it warms up. Which, given how long it takes a 1 lb frozen steak to thaw, you might be waiting quite a while for a 120 lb hunk of metal to warm up...
    (However, metal is more conductive than meat, and there's no phase transition to go through like the water in the meat will when thawing; so it's possible the battery will actually "thaw" faster than a steak under the same conditions... But I don't have either a frozen steak or a frozen battery, so I won't be testing this any time soon. ;))
  3. kc410
    kc410 Active Member
    262
    251
    2010 Prius IV
    Seems the Prius may be trying hard to protect the hybrid battery. The only possible way to warm the hybrid battery is by charging/discharging. If the ICE were to idle & also supply all the power requirements of the vehicle, the hybrid battery sits & does nothing. By slowly cycling the hybrid battery, heat will be generated internal to the traction battery, warming it.
    When you have one of these "Abnormal" conditions how discharged is the traction battery allowed to go before it gets recharged? I have found the dash battery gauge quite inaccurate. Instead I use the SoC (State of Charge) pid in Torque, which follows the true SoC quite nicely.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'm a little unclear, between your two scenario's Normal and "Abnormal"...there is situational difference? And that is outside temperature? So your abnormal behavior is only manifesting when it's cold outside?
    Also the first marker of what "situation" you happen to be in, seems to be whether when you "park" the ICE either shuts off (normal) or (keeps running) abnormal. Since in both scenario's you say the ICE is at the same temperature when you park.
    I guess I have to ask the obvious, and that is how do you define "park". I'm assuming you are in "P"-park...with the parking brake set, but the Prius left ON?
    Since you say once you start driving, and come to a stop it seems to "return to normal", that would tell me that it isn't "physically" something wrong with your battery. If it was something wrong with your battery, it would never "return to normal".
    I'm sure as you know, the Prius operates in at least two ways, 1. To keep the engine warm, to help maintain clean emissions. 2. To run the engine to maintain hybrid battery charge.
    You seem to be noticing a specific scenario where the engine is running but the battery isn't maintaining charge.
    So I guess my final set of questions are:
    In your "abnormal" scenario, do you ever just let it go? In other words, just let the engine keep running until the battery get's really, really low? In the abnormal scenario you say the engine does NOT turn off? If so does the engine temperature maintain or drop?
    You also say when you observe it is behaving "abnormally" you shut down and restart? Have you ever tried NOT doing this? As every time you shut down, your engine is going to cool, and every time you start, the Prius is going to go into "start up" mode.
    I guess my advice is next time you are forced to idle, and are observing the "abnormal" behavior, try doing nothing. I don't know how long your idle time is...or how extreme your outside temperatures might be in any given scenario, but the Prius is designed to not let the HV battery get too low, so at some point it should start taking a charge or get so low, that it throws a code.
    Also curious...how "cold" is "cold" outside? If we are talking really extreme low outside temperatures you might just be witnessing "normal" Prius behavior in trying to protect itself while parked.
  5. bisco
    49,460
    check your 12 volt health.
  6. The Electric Me
    9,083
    5,798
    Or....this....
  7. Rishar
    US
    The traction battery/hybrid battery never drops below the minimal of 40%. The lowest I've seen it while sitting in park with vehicle on is 48%. I also use Torque to monitor the SoC.
    The situations are the same, it's always when it's cold out. Anywhere below 20 degrees out.
    This is always after an hour of driving. So the ICE coolant and engine temp are always at the running temp of 195F
    I define Park by having stopped, push the Park button, leaving the vehicle on.
    The strange part is that the hybrid battery drains VERY slow. About 0.4% every 2 minutes. As the engine stays running the entire time the engine temp stays at the 195F it started at when I stopped driving and put the vehicle in park. I've let it sit like this for about 25 minutes. The battery charge had not drained below the 40% minimal level.
    12 volt auxiliary battery has been checked and is in perfect working order holding a good charge.
  8. The Electric Me
    9,083
    5,798
    Well, I'm just really tempted to say I'm not convinced you have a problem at all.
    If it's cold outside and you are sitting in park, the vehicle will run the engine to maintain temperature and to charge the hybrid battery. If you are doing this, even if the engine is running but you've never seen the hybrid battery drop below 40%, then I think the system is just doing what it is suppose to do.
    Have you ever tried "force charging" the battery in this scenario? Because from what you are describing I really don't think it's a case of the battery not taking a charge at idle.
  9. Rishar
    US
    The only reason I assume this is a problem, is that normally, the engine idling would be doing exactly what you say, force charging. I've seen the battery get up to a little over 70% just from idling. But I've never seen it do what it has been, which is not charging while the car is idling and engine is running in the past year I've owned the car. Nor have I ever seen it not shut the engine off when these conditions are met.
    A warm engine (in this case 195F).
    A charge over 40% (58% is where this started and at which point I was in park)
    Car is in park/stopped/or coasting below 42mph
    Having gone through it's various warmup stages. After driving an hour, it certainly had. Especially since it hits S4, even in the coldest temps, after about 10 mins of light driving. And I'd done an hour of highway driving at 55mph.
    If you do not believe it's not taking a charge, do you have a thought as to what might cause it to slowly drain despite being below a 60% charge (the optimal charge the Prius likes the battery at) and the engine idling at over 900rpm which should be charging the hybrid battery? It's not a normal behavior for this car and is certainly worrying me.
  10. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    Have you notice a hit in recorded MPG?
  11. The Electric Me
    9,083
    5,798
    I could be wrong.
    But I think you are paying closer attention to immediate behavior than most people.
    If you've never seen the battery drain below 40%, but you think the battery is slowly draining and would never charge? Then I think what you need to do is let it go until it does drop down to where it would obviously need to charge or the system would throw a code. In your case, what I would be curious about would be if I could get the battery so low, 2 bars or less, and then whether it charged itself or not. If you find that there is a point that the battery DOES receive a charge? Then I think the system IS working. Just not exactly the way you think it should. If it "slowly" drains way too low? I would think it eventually would throw a code. Then at least you would have a starting point for evaluation.
    As far as to "why" would it be slowly draining. My guess is as long as The Prius is ON, even if parked and with few or no accessories on, there is still probably a minimum drain that happens just in operation.
    I'm not an expert on exactly how The Prius software may or may not prioritize how it uses engine generated energy in any specific situation. But I would assume that it runs it to maintain 2 conditions, keeping the engine warm, and keeping the battery charged within a certain range. Seems to me even though you are carefully watching "how" this is happening, the end result is that The Prius is doing both things. Your charge is not dropping below 40% and your engine is being kept warm.
    Good Luck.
    PS.
    In my test scenario, I wouldn't really want to let the battery drop too much below 2 bars. You want to see if it ever responds and starts charging, or throws a code, BUT you don't want to strand yourself or cause any permanent damage. I'd say if it drains down to 2 bars or less and at that point it isn't charging the battery? Then you indeed do have a problem.
  12. bisco
    49,460
    since you checked the 12 volt health, can you give us the readings? or are you relying on a service monkey's word?
  13. Former Member 68813
    3,524
    981
    US
    i've noticed similar, but the opposite, in hot weather with AC on, sometimes the ICE cycles and sometimes it just runs all the time while sitting ready in park.
    PriusGuy32 likes this.
  14. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    Stop trying to overthink the cars built-in battery safeguards, and just drive the car. (y)
    Same here.
