Hybrid battery stops charging intermittently
Discussion in 'Gen 3 Prius Technical Discussion' started by car78412, Mar 20, 2019.
  1. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    The Hybrid battery does not charge. It has happened twice so far and I am concerned that this will become a larger issue. The yellow triangle does not appear. In fact the only indication is that the battery bars drop to two and the charging bar indicator shows no charge . When I stop and turn the car off then turn it back on, the charging goes back to working normal. Has anyone have this happen in their Prius? I have a 2010 IV with 97000 miles.
    51,155
    The battery does not always charge, so I’m not sure exactly what you mean
  3. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    The hybrid battery does not indicate an increase of bars when braking. The battery drains down to 2 bars and does not increase. The charging indicator does not show charging while driving/braking. Shows no codes or problem lights on dash.
    51,155
    so, no matter how far you drive, it never comes up from 2 bars unless you shut down and restart?
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Based on your join date, I'm assuming you have plenty of experience with this car so it's not pilot error. I think I'd be taking it to Toyota or a trusted hybrid specialist to let them check it out. Something sure sounds strange.
  6. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    So, you're saying this display never goes into the CHG portion? It should definitely enter this portion when braking, and possibly during coasting also.
  7. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    If you have your origional 12v battery, I'd start by getting a new one and charging it.
