Hybrid Battery Temperate Probe Clips
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by RichV, Jul 3, 2022.
  1. RichV
    RichV Junior Member
    Decatur TN
    Anybody have a part # for the temperature sensor probe clips that attach the thermistors to the individual cell in the hybrid battery? Mine are technically working, but are brittle and a couple have only 1 side of the clip actually attached. I havent been able to locate a part # for these. The wiring harness itself is fine so I really dont want to buy another just to get good clips
    Even better if someone has made a .STL file to be able to 3d print these suckers!
  2. PriusCamper
    PriusCamper Senior Member
    11,055
    4,499
    Pacific Northwest, USA
    Any battery rebuilder has loads of these temp sensor harness. Just get one from them... Toyota will likely charge hundreds even though the harness cost less than $5 to make. And if it's just the plastic clip you need not sensor I could mail you a couple?
  3. RichV
    RichV Junior Member
    Decatur TN
    Hmmm, not letting me DM you right now.. yep I just need the 3 plastic clips, my NiMH cells are on their way out, so I'll probably be hitting that link in your signature file for the NexCells as well :) I see they should have a batch in anyday
  4. PriusCamper
    11,055
    4,499
    Yeah... DMs don't work on here for most people. But I was able to start the conversation so now you can reply to my DM.
